2007 Cooper S Cooling System Oddity
Old Sep 24, 2016 | 10:23 AM
Steve Conner's Avatar
Steve Conner
I could use some expert advice. As stated above, vehicle is 2007 Cooper S hatchback (turbo) with 82k miles. Had the temperature light coming on, and had heard about water pump problems, so I bought the Pelican Parts cooling system super kit. It includes the thermostat, water pump, expansion tank cap and most of the system hoses. I installed all this stuff and wanted to bleed the system in the garage, before risking a road trip. At first I couldn't get any hot air from the heating system, no matter how long the car had idled. I took the heater core out to check it, and it was completely fine. Perhaps I still had some air in the system. Since then, I have heat cycled the engine several times and topped up the coolant each time after it cooled. The heat inside is working fine now, also. I just took a 15 mile road trip and had no temp lights come on, but when I pulled it in the garage and felt the lower radiator hose, it was cold, not even warm! What gives? Am I looking at a clogged radiator? I'd appreciate any thoughts.
Steve Conner
Old Sep 24, 2016 | 12:21 PM
oldbrokenwind's Avatar
oldbrokenwind
The hose directly under the radiator only flows during extended hard acceleration, or when the A/C is set to "Max". It's kinda an emergency source for coolant.
Merv
Oct 25, 2016 09:07 PM
98Ekhatch
Aug 16, 2016 01:56 PM
Photodesign
Aug 12, 2016 10:24 AM
RichCamp45
Aug 12, 2016 10:23 AM
Photodesign
11
Aug 9, 2016 07:31 PM
