Yellow Brake Light with Yellow ! with circle on Startup
Old Sep 15, 2016 | 12:52 PM
Bgould's Avatar
Bgould
Hi Everyone. I recently purchased a 2008 Mini Cooper S 6 speed with 89000 Miles. When I start the car there is a yellow circle with and exclamation point in the middle of it. This only stays on for a short time. When I release my emergency brake, the brake light changes from red to yellow. Can any one give me ideas as to what the issue may be? Let me now if you need any more details. Thanks in advance.
Old Sep 15, 2016 | 01:00 PM
MiniToBe's Avatar
MiniToBe
check your brake fluids, check the pads, check fuses in the front and behind the kick panel of the passenger side. also pix are helpful from before and after.
Old Sep 15, 2016 | 01:03 PM
Bgould's Avatar
Bgould
Thanks for the tips. I have checked the fluid level and that was fine. I will check the rest and let you know what I find.
Old Sep 15, 2016 | 01:12 PM
MiniToBe's Avatar
MiniToBe
also, you can scroll down the menu to "check" ot "service" and it'll tell what that might be the issue. also, try to reset it from there as well and see if it comes back or doesnt go through with the reset. do the brakes feel lower than normal?
Old Sep 15, 2016 | 08:13 PM
Semaphore's Avatar
Semaphore
This worked for me, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You can reset the code as well with the right app.
Old Sep 16, 2016 | 05:35 AM
Bgould's Avatar
Bgould
I attached a picture of the light. I checked the fuses, and there were no service resets. I have a similar code reader but didn't find any codes. I will download a different app and see if that makes a difference. This weekend I will inspect the brakes and see how they look. Thanks for your help so far.
Attached Thumbnails Yellow Brake Light with Yellow ! with circle on Startup-light.jpg
Old Sep 16, 2016 | 05:40 AM
MiniToBe's Avatar
MiniToBe
I think this is for the anti roll system. When you are up hill, does the car roll back when you put in the first gear and release the brake while the clutch is pressed?
Old Sep 16, 2016 | 06:58 AM
Bgould's Avatar
Bgould
I am almost positive that the car rolls back when on a hill. I will give it a try in a little while. Is that an expensive/difficult issue to fix?
Old Sep 16, 2016 | 07:21 AM
MiniToBe's Avatar
MiniToBe
Check the fuses also. Remove and reinstall the fuse to reset the system. There are few things to look at to fix the issue IF confirmed that there is an issue. One is to reprogram the abs module, two is to look at the transmission dual mass plate, three is to ignore the issue and just drive :-)
Old Sep 16, 2016 | 10:52 AM
Bgould's Avatar
Bgould
The car definitely rolls backwards on a hill so that must be the issue. I pulled the fuse and that didn't reset the problem.
Old Sep 16, 2016 | 11:26 AM
MiniToBe's Avatar
MiniToBe
I did a test with my 09 clubman s 6sp. i removed the fuse and the light came on with yellow brake light. i put it back and it went away.
so there is something there to be looked at. what was the reason you got the light?
I did not check fuse F16 though to see the outcome.
Old Sep 16, 2016 | 12:25 PM
Bgould's Avatar
Bgould
I removed f16 as well. The light was on when I purchased the car.
Old Sep 16, 2016 | 12:28 PM
MiniToBe's Avatar
MiniToBe
aha...how far from philly PA are you?
Old Sep 19, 2016 | 11:43 AM
Bgould's Avatar
Bgould
I am a few hours from Philly. I also do not think the traction control is working correctly either. On wet roads the wheels spin and the wheel turns hard to the right.
Old Sep 19, 2016 | 11:51 AM
MiniToBe's Avatar
MiniToBe
There are few elements to the ABS unit and these are some of them. I dont want to say your ABS is shot, but it is worth having it reprogrammed. there is also a YAW sensor under the passenger seat that may not be working properly. Was there water intrusion any where in that area? Can you also confirm the plug is tight are the ABS module. Do you have any programming tools like NCS expert and WinKFP?
smarsha11
Sep 18, 2016 08:49 PM
Jolio
Sep 8, 2016 04:49 PM
JMiniCoop
Aug 24, 2016 02:35 PM
alexinvancouver
Vancouver Mini Cooper Club
Aug 16, 2016 02:32 PM
Classic Mini Talk
Aug 16, 2016 01:20 PM
