Need Help Fast!!!
Old Sep 13, 2016 | 06:46 PM
Ronald Wright's Avatar
Ronald Wright
Need Help Fast!!!
Alright here we go, I recently purchased 2009 Mini Cooper S 6mt w/Keyless in New Hampshire and I've been enjoying it but the other day(Monday) as I was doing my routine route before work I stop at my local Dunkin' turned off the car and got my coffee than tried to start my car( after I had to put something into the trunk) and than it clicks so I used my other car to try and jump it and nothing but I had power too everything but no engine start so today(Tuesday) I took the battery too the auto part store and they confirmed that the battery was super dead and they changed it so I pick it up in a hour and installed it and tried again to start but this time I still have power to windows,locks and radio but no display or info on gauges and ther is no mini dealer around where I live which I live in the A/L area of Maine. Please help or any mini owners in my area point me in some kind of direction. Thanks in advance
Old Sep 13, 2016 | 10:47 PM
oldbrokenwind's Avatar
oldbrokenwind
My guess is you have the "Intelligent Battery System". If there's a "box" at the battery ground terminal --- something more than just a clamp --- that's an indication of what it is. This usually requires a new battery to be "registered" by the dealer --- about a 1 ½ hour process where the ECU "learns" there's a new battery installed. This will keep the alternator from overcharging the new battery, among other things.
If you have this EBS installed, I suggest you contact a dealer fir instructions.
Old Sep 14, 2016 | 05:23 AM
MiniToBe's Avatar
MiniToBe
That should not stop the car from starting though. I used to unplug it and start the car and it would work. there might be a ground connection that got loose. check the ground strap by the engine mount on the left (the engine is in front of you) did you ever have any other issues prior to this or any recent work done ?
Old Sep 14, 2016 | 06:26 AM
Ronald Wright
I'm going to check everything you guys told me so far but I only have had the car for about 4 days and don't know too much on history only what is Visual
Old Sep 14, 2016 | 06:30 AM
MiniToBe's Avatar
MiniToBe
also, when you get a chance, take a short video of the engine bay and when you start it. can you also check the oil level and antifreeze. when you bought it, what did the previous owner say about the car, why did he sell it and how long did he have it for, how many miles the car has? where in the States are you?
Old Sep 14, 2016 | 08:36 AM
bugeye1031's Avatar
bugeye1031
Moderator
I'll add my two cents....check that the positive and negative battery clamps are actually on tight. I've re-installed the battery on my '09 and tightened the clamps, drove it for a few days and then a dead battery....just to have a mechanic tell me that the clamps weren't tight. They're not a great design....used by other manufacturers also....I think that they've replaced it with a better design that doesn't "lock up" and appear tight when they are not.
Old Sep 14, 2016 | 11:02 AM
Ronald Wright
I figured out why the cluster wasn't working, when I was checking the fuses I put it back in the wrong slot but still have a no start problem. Is there a facebook page everyone used I can load it there too make it faster.
Old Sep 14, 2016 | 11:50 AM
MiniToBe's Avatar
MiniToBe
waaaaait...i have an idea did you try to pop the clutch?
Old Sep 15, 2016 | 06:33 PM
Ronald Wright
It was the starter, tried too test it and failed.it was fried thanks everyone for your input I'm up and running again.
Kristopher Sullivan
Tires, Wheels, & Brakes
12
Jan 10, 2017 07:33 PM
cs1234
Dec 11, 2016 12:45 PM
Nicbay350
Aug 10, 2016 08:18 AM
dorkfaceandrew
Aug 10, 2016 01:41 AM
APDspider
Aug 7, 2016 07:59 PM
