R50 - How to remove side skirt?
Old Sep 11, 2016 | 02:05 PM
RudeJoe's Avatar
RudeJoe
First let me say that Bentley is useless!!! Also, I did a search here and could not find a good instruction.
I'm trying to remove the Left side skirt and can't figure out how to get at the clips on the back side.
I've got the top and bottom clips removed, well, most of them destroyed. The top clips I just pulled up on the skirt and they popped through. I'll get them out later.
One thread I found said to get at the front and back clips through the wheel well and then slide the skirt forward to disengage the others. The picture on the ECS's website suggests otherwise to me. It looks like some of the interior clips oppose each other (one would need the skirt to slide forward and the other to the rear to disengage).
Any help would be appreciated!
Old Sep 11, 2016 | 08:18 PM
Brochacho's Avatar
Brochacho
If the one circled in orange is removed via wheel well, the two in red look to me when blown up on large monitor, will come off if slid in the direction of the green arrow.
Old Sep 12, 2016 | 12:54 PM
+1 Thats correct, watch those clips , they like to slide out and break the tabs, just take it easy.
Old Sep 12, 2016 | 01:19 PM
RudeJoe's Avatar
RudeJoe
I figured out why I got it reversed - that image is the right side skirt not the left side. It was incorrectly shown in the left side listing.
I did get it off and ended up breaking most of the clips in the process. The skirt needed to slide forward to disengage the clips, not rearward. I tried sliding rearward like recommended in one thread. When one didn't work I pulled a little too hard trying to look at the clip underneath. The first one popped and, thinking they were popping out of the side skirt and not breaking, I started pulling my way down the length of the skirt. When I got to the last one I looked and noticed I had broken off one ear of each clip. I guess I need to take more time and also wait for a response here before going with the gorilla method.
ECStuning - Is there a kit with all the fasteners or do I need to buy all of them individually? The parts seem expensive for what they are. I was able to save a few of the underside two part clips but all the backside clips are gone.
Old Sep 14, 2016 | 07:05 AM
Individually for those :
07131480419
https://www.ecstuning.com/Search/SiteSearch/07131480419/ES16410/
Old Sep 14, 2016 | 07:31 AM
MiniTigger's Avatar
MiniTigger
So do they slide toward the front or rear of the car? Can you remove it without breaking any of the clips?
Old Sep 19, 2016 | 06:23 AM
MiniTigger's Avatar
MiniTigger
bump
Old Sep 19, 2016 | 06:02 PM
Brochacho's Avatar
Brochacho
Looks like to the front. Hope that helps.
Old Sep 22, 2016 | 10:14 AM
Red ones to the front, so they side out. Orange circle one in the wheel well access.
Old Oct 16, 2016 | 11:02 AM
RudeJoe's Avatar
RudeJoe
So finally finished all the work I need to do with the side skirt off and bought replacement clips (thanks ECS). Now I need to put this back on. Do I put the clips in the skirt and then push the skirt on? Do I put the clips on the body and then slide the skirt on?
I know some of the other trim pieces come with clips installed and they just push on.
The only reason I question this assembly method with the side skirt is because the clips are so rigid I'm not sure they will flex enough to push on. To get the old clips off the body they need to be turned 90 degree to pull out as the hole is rectangular. I guess I'll experiment with a single clip before trying to push all of them on.
TIA
Old Oct 16, 2016 | 02:52 PM
RudeJoe's Avatar
RudeJoe
OK, I went ahead and gave it a try and they pushed in easily while on the skirt.
Old Oct 17, 2016 | 08:32 AM
Welcome. Glad to help.
Phillbis
Jun 6, 2020 09:24 AM
MarioKart
May 14, 2019 10:10 AM
MrBlah
Aug 19, 2016 08:17 AM
gfx
R55 :: Clubman Talk (2008+)
Aug 16, 2016 07:54 PM
alexinvancouver
Vancouver Mini Cooper Club
Aug 16, 2016 02:32 PM
