R50/53 Brake caliper- how to prevent this type of excessive corrosion?
Old Sep 8, 2016 | 04:10 AM
RudeJoe's Avatar
RudeJoe
One rear brake on our Mini was not functioning well so we took a look at it. The rubber boot protecting the guide pin was distorted so we took it out. Here's what we found. Lots of white build up. It came out with a file and wire brush but I'd like to prevent this in the future. Will Anti-seize compound work or do I need something else? I'm in the northeast, lots of snow and salt in the winter. Thanks
Attached Thumbnails Brake caliper- how to prevent this type of excessive corrosion?-image1.jpg   Brake caliper- how to prevent this type of excessive corrosion?-image2.jpg
Old Sep 8, 2016 | 04:54 AM
ZippyNH's Avatar
ZippyNH
The rears unfortunately tend to fail, corrosion or not...
Externally you can paint them....
Internally....more flushing....
But short pulling off the rubber bushings on them to lube them (yes, if you look at the mini inspection 1+2 list, it does say lube and inspect....
Magnesium-chloride is even worse than salt corrosion wise....you can try to rinse stuff off more, but most of the typically oily anti-corrosion sprays are not going to play well with brake parts....
And living in the NE, I had my rear OEM brake rotors fail inspection...barely 4 years.....the edges were corroding and puffing... coming off in layers...the caliper survived till it was about 10 years old.
andrewjg1994
Sep 3, 2018 08:16 AM
honderpilot
Aug 19, 2016 04:40 AM
TJANK
Aug 18, 2016 02:55 AM
cop1406
Aug 16, 2016 09:33 PM
TJANK
Aug 15, 2016 11:28 AM
