R56 2013 Mini Cooper s hatch back transmission swap
Old Sep 7, 2016 | 07:34 PM
Aegean1998's Avatar
Aegean1998
I'm new to the forum -and honesty don't even know if I'm in the right thread- but I wanted to know if anybody had any Idea how to go about changing the transmission from automatic to 6speed (where to get the tranny, labor cost, ect...) if anyone can help that would be great
Old Sep 7, 2016 | 09:00 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Sell your car and buy the other one. Must easier and way cheaper.
Old Sep 8, 2016 | 10:58 AM
oldbrokenwind's Avatar
oldbrokenwind
Don't even think about it! ECU's are programmed for one OR the other, not both. It probably can be done, but you need some serious motivation for the grief involved. And when you're all done, what have you got that was worth all the trouble?
Old Sep 8, 2016 | 12:57 PM
MiniToBe's Avatar
MiniToBe
why do you want to do the swap? it it could be done and the ECU can be programmed for that option using NCS expert and some other software. i am not sure if you have to drill out for the clutch or if there is a pre-marked hole. finally, there is wiring harness that needs replacement and most likely goes behind the dash...easy yet time consuming. if it is your daily driver, it isnt worth the trouble. what is the budget you have in mind for this?
Old Sep 8, 2016 | 01:22 PM
Aegean1998's Avatar
Aegean1998
I'm selling another car for around 3500ish, so that or a little above
Old Sep 8, 2016 | 06:37 PM
MiniToBe's Avatar
MiniToBe
I think I have all the parts for the swap, but not sure if it would work. I have two spare mini coopers clubman s manual. One is a 2008 and the other is a 2011. If you want, I can take a look at the wiring and how things are constructed and let you know...where are you in the states?
Also, what are the options you have on the car?
evilmini55
Apr 4, 2017 06:25 PM
Geronomo
Sep 29, 2016 08:12 AM
OldCoot
Sep 20, 2016 08:20 PM
PelicanParts.com
Sep 8, 2016 08:38 AM
jmedina94
11
Sep 3, 2016 09:24 PM
