Replaced Thermostat, P0597 Remains, Next Steps
Old Sep 7, 2016 | 07:16 PM
scarabbrian's Avatar
scarabbrian
I replaced my thermostat after my car threw a P0597 code, but the P0597 code still remains. As I see it, there are two possibilities as to why the code remains: the replacement part is bad or I've got a break in the wiring. In order to figure out which, I'm wondering if anyone can answer what the resistance of the thermostat is supposed to be and where on the connector into the computer the thermostat is placed? Any other suggestions on how to proceed would be much appreciated.
Old Sep 9, 2016 | 12:14 PM
nkfry's Avatar
nkfry
1. Did you mix up the PCV heater connection and the thermostat temp sensor connection? It can be done, and will cause weird problems with coolant temp and thermostat codes. The thermostat temp connector on the harness is green, the PCV heater is brown.
2. The part could be faulty, we had one last week that we had to warranty out after about a week of being installed.
3. Is the car an automatic? The thermostat codes could be stored in the transmission control module and need to be cleared.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 9, 2016 | 12:35 PM
scarabbrian
Thanks for the reply! I didn't mix up the wires: brown connector to the temp sensor, green to the thermostat. The thermostat could be faulty, which is why I was asking about the resistance. I measured 16Ω on the new thermostat and 530Ω on the old thermostat. I don't want to blindly replace the thermostat again without someway of verifying that the new one is broken. Since the thermostat is a solenoid, I know of no better way to check if it's okay or not than to check the resistance. My car is a manual so I don't think the issue is with the code being in the transmission control module.
Old Sep 9, 2016 | 01:56 PM
nkfry's Avatar
nkfry
Okay, well if you bought a MINI part they carry a 2 year unlimited mile warranty. If it is in fact faulty the dealer will replace it for free (after you pay the diagnostic up front).
Many aftermarket parts also carry a 1 year warranty, but they don't warranty labor and coolant to do the job.
Phone:586-792-6464
Old Nov 26, 2016 | 07:35 AM
Dhagnew's Avatar
Dhagnew
Culprit?
I also recently replaced my thermostat and code P0597 is back. Did you end up getting another thermostat?
MrSurly
Aug 29, 2018 04:44 PM
fixthedoor
R55 :: Clubman Talk (2008+)
Sep 14, 2016 07:03 AM
froggy_07
Sep 7, 2016 02:56 PM
splaterfsce
Sep 7, 2016 01:31 PM
miniuy
Sep 5, 2016 06:40 PM
