R56 short shifter
Old Sep 5, 2016 | 08:55 PM
chav's Avatar
chav
short shifter
Had some questions about buying a short shifter. I like the clean look of not have the shifter boot. I was thinking about the one ecs has ( https://www.ecstuning.com/b-megan-ra...FQoxaQod94UOKA )
But I will also need the box that's actually under the car correct?
https://www.ecstuning.com/Mini-2009-...16C/ES2843635/
Then if I want the clean look I have to buy the cover and stuff
Old Sep 5, 2016 | 09:31 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Unfortunately, the Megan shifter in the ECS link is for a Gen 1 R53.
Old Sep 6, 2016 | 09:47 AM
chav's Avatar
chav
Dang I really liked that one.
Old Sep 6, 2016 | 09:59 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Yep the Megan is a sweet looking shifter. +1 to the CravenSpeed short shifter though. That's what I put in Vlad along with the NM box cover and weighted shift ****.
Old Sep 6, 2016 | 01:26 PM
Yes, those are for Gen 1 MINIs.
For a short shifter you will need
https://www.ecstuning.com/Mini-2009-Cooper-R55-John_Cooper_Works_Clubman-Coupe-L4_1.6L_N14B16C/Interior/Shifter/ES2843636/
https://www.ecstuning.com/Mini-2009-Cooper-R55-John_Cooper_Works_Clubman-Coupe-L4_1.6L_N14B16C/Interior/Shifter/ES2843635/
Old Sep 7, 2016 | 03:23 AM
sgscomps's Avatar
sgscomps
nm-engineering is a quality part and really shortens the distance between shifts. Make sure to get the extended cover to keep the junk out. nm-eng.com
Old Sep 7, 2016 | 09:54 AM
bugeye1031's Avatar
bugeye1031
Moderator
I've had both the NM and the CravenSpeed in the same car (Clubman S). I converted from the NM to the CS because a friend sold his MINI and I bought his CS SSK. The NM unit is excellent - no complaints. I'm glad that I converted though - the CS can be adjusted (length of throw/"notchiness") which allows me to dial in just the right feel. My goal for my Clubman is to make it as much fun to drive every day as possible, and the CravenSpeed SSK helps with that. I also have the CS well cover and the CS engraved shift **** - a great setup for me.
Also, CravenSpeed is an outstanding vendor to deal with. I don't have any relationship with CravenSpeed other than being a customer.
Old Sep 7, 2016 | 11:55 AM
chav's Avatar
chav
Okay great to know! I have herd great things about their weighted shift ****.
AlphaQuad
Mar 29, 2016 07:07 PM
camptown
Mar 22, 2016 07:39 PM
Mar 18, 2016 02:48 PM
Storer
Feb 10, 2005 02:27 AM
