Burning oil - 1 quart per 500 miles
Old Aug 31, 2016 | 08:41 AM
KumarS's Avatar
KumarS
I have a 2008 Mini Cooper S with 63k miles.
My driving conditions are normal (daily commute to work 18 miles each way).
my last service was done at 60500K miles
  1. oil changed
  2. replaced oil filter housing gasket
  3. replaced oil pan gasket
  4. replaced vacuum pump.
  5. performed a intake valve deep cleaning due to too much carbon deposit.
Recently the car seems to be burning lots of OIL. @62k miles I have added 1 quart of oil and another 1 quart at 62.5k miles. Now at 63k the Mini is demanding for another quart of oil. This car burns lots of oil 1 quart for every 500 to 600 miles.
Is there anyone out there facing similar issue of burning too much of oil. What could be the cause of this oil burning and suggestions to trouble shoot the issue ?
Old Aug 31, 2016 | 09:12 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
if it's not over full and you cant see where its going, it's probably the turbo seal
Old Aug 31, 2016 | 10:53 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Oil consumption that exceeds 1 quart per 750 miles is considered excessive and is in need of additional diagnosis.. Double check and make sure there are no leaks. We have an oil consumption tech article that goes over a lot if you have questions about it. We include this in the article:
Here is a summary of potential causes of high oil consumption:
Incorrect viscosity oil
Crankcase ventilation system faulty
Oil diluted or contaminated
Mechanical leaks: Seals, piston rings, valve seals, gaskets
High speed driving, heavy loads
Heat wave, city driving, incorrect fuel
Engine overfilling
The article goes into further detail of the above items on our site under the "tech info" tab at the top. Hope you get your issue figured out. Good luck.
888.280.7799 | 6am - 5pm PST
Old Aug 31, 2016 | 05:40 PM
AZdsrt's Avatar
AZdsrt
I've seen a few threads on here about the PCV in the valve cover, which required the entire cover to be replaced..
Old Sep 5, 2016 | 10:34 PM
hockeydad2000's Avatar
hockeydad2000
My 2010 Cooper S burns about a quart of oil every 1500 miles. To me that's ridiculous. My 1980 Camaro I drove in High School in the 80s didn't burn oil at this rate. How can BMW smugly claim that's normal, meanwhile Honda can build engines that burn no oil and produce the same hp?
Old Sep 6, 2016 | 05:01 AM
Mini3333's Avatar
Mini3333
I had a similar problem on my 2008 MCS...it loved to drink oil. I solved the problem by trading it in.
Old Sep 6, 2016 | 07:01 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
  1. oil changed
Recent onset of oil consumption for the Prince Engine can be attributed to lack of proper crank case ventilation. Your model has a dual PVC system built INTO the valve cover itself so not as easy as with most other cars or prior years.
New valve covers cost appx $360.00 and come complete with new cover gasket.
S1m0n
Jun 4, 2016 06:37 AM
moremini
Apr 20, 2016 07:08 AM
JWA
Mar 20, 2016 04:29 PM
normstangl
Aug 23, 2007 02:24 PM
miniminimini
Jul 11, 2002 09:49 PM
