car just turns off
Old Aug 27, 2016 | 07:41 PM
Mini_Chan's Avatar
Mini_Chan
car just turns off
My 04 r53 has over 100k miles...the car would sometimes just die with no warning when I am stopped at a light. Everything turns off, and the needles on the speedo would be stuck at the position it was in. All electrical would be completely off, can't even turn on hazards. Sometimes I can park my car, and come back to it later. I would not be able to unlock my car with the key fob, and I would have to manually unlock it with the key. The clock would reset to 0:00, all the stats on the ecu would reset as well. The battery on the car is a little over 2 years old. Went to get it tested and battery is still good. However, my alternator was failing. So I just replaced it today, and everything looked good, until the car died again...
Not sure what else is wrong with the car...
Old Aug 27, 2016 | 08:56 PM
Fly'n Brick's Avatar
Fly'n Brick
First thing to do is go over ALL of the ground straps and check them for grease or corrosion and tightness.
Old Aug 28, 2016 | 10:52 AM
Mini_Chan's Avatar
Mini_Chan
I took a look at all the ground straps and there was no corrosion and everything was tight
Old Aug 28, 2016 | 06:46 PM
Mini_Chan's Avatar
Mini_Chan
https://www.northamericanmotoring.co...l-problem.html
This thread shows the exact problems as mine. But I don't think they ever found the solution.
Old Aug 29, 2016 | 07:40 AM
MiniToBe's Avatar
MiniToBe
it seems he might have done the starter? i dont know much about the R50, 53. but i hope you get it fixed soon
Enjoytheride
May 6, 2016 01:34 PM
Cmv138
Apr 11, 2016 06:18 AM
co0p3r
Mar 28, 2016 07:46 PM
JWA
Mar 23, 2016 08:37 PM
Lopez421
Mar 15, 2016 09:30 AM
