Autoleveling headlight help
Old Aug 24, 2016 | 10:42 PM
50shadesofr53's Avatar
50shadesofr53
I've been searching and reading trying to find a way to effectively test my headlights without going into traffic and jamming on the brakes. I also can't find I clear answer on if the lights on my 06 mcs are supposed to auto adjust full time (left right up and down) while driving or just up and down? I notice them do the test when I first turn them on, but after that I feel like they just stay there.
Old Aug 24, 2016 | 11:25 PM
RB-MINI's Avatar
RB-MINI
What about using a floor jack and a wall to watch the beam pattern? You can also manually move the arm on the leveling sensors to see if the headlights move.
Old Aug 25, 2016 | 12:03 AM
50shadesofr53
I did this, and I didn't really notice any movement at all. Maybe a flicker if that
Old Aug 25, 2016 | 11:39 AM
yes, unbolt them and see if they move with the lights. 37146784698 & 37146853759
One on the front and one on the rear.
https://www.northamericanmotoring.co...king-help.html
Old Sep 5, 2016 | 05:51 AM
Brochacho's Avatar
Brochacho
I set the e-brake and put car in reverse, let out clutch a little it will lift the rear of car a little. Then same in first gear, it will squat the rear of the car. A masking tape line/reference point on garage door. Mine say at same point on tape line.
Old Sep 5, 2016 | 11:32 AM
50shadesofr53
I have moved each sensor individually with no movement. When I'm out playing in town you can watch the headlights bounce with the car, even with the ebrake trick, headlights move with the car
Old Sep 6, 2016 | 02:07 PM
Did you check the connections at the plugs and the fuse for the headlight sensors.
Old Sep 6, 2016 | 02:43 PM
50shadesofr53
The front plug is broken but is still making connection.
Having a tough time finding the fuse for the sensors themselves
Old Sep 11, 2016 | 02:42 AM
Brochacho's Avatar
Brochacho
Weird...I'd think if they move during initially turning them on, they work. I didn't think they move instantaneously with movement of the sensors either...But it's been awhile since I tested. I'll look in the morning and when I get off work and pinpoint the fuse(s).
minigen
May 2, 2016 02:33 PM
cl_reatta
Apr 1, 2016 08:43 PM
Omatic
Mar 22, 2016 07:46 AM
greatgro
Jul 24, 2002 09:01 AM
