R50/53 Swapped the engine, new one cranked but now it won't start...
Old Aug 20, 2016 | 01:10 PM
atsatsa's Avatar
atsatsa
Ok, I recently swapped out my bad engine and replaced it. Before putting everything back together, I started the replacement after I got it in with a jump pack to make sure it worked and it cranked just fine. I ran it for about 10-15 seconds.
Then, I put on a new water pump, the original alternator, the radiator and put in a new battery. Now it won't start. The starter does not click at all, but all the lights on the dash come on. I double checked the wires and everything seems to be soundly connected.
Is it an immobilizer issue? Can I take out the EWS, ECU and take the key in for them to align it, if so?
Thank you
Old Aug 20, 2016 | 05:27 PM
David.R53's Avatar
David.R53
The engine has no chip or ID built in. If you didn't change the ECU, it won't care. Check your grounds, see if you are getting voltage at the starter, all the basics...
Old Aug 20, 2016 | 08:04 PM
MiniToBe's Avatar
MiniToBe
Yup, check grounds.
Old Aug 24, 2016 | 04:30 PM
atsatsa's Avatar
atsatsa
Update.
I took the starter out and connected it straight to the battery with some jumper cables and then used a screwdriver to touch both posts and other than a little spark, nothing happened, so I thought the starter just kicked. I put in a different starter, and and still all the lights come on but no clicking. I borrowed a voltmeter and checked the voltages coming from the battery, it was fine. I checked the voltage at the battery post on the starter, and it was about 7. I'm not really what to do now, as I'm still learning (obviously as I go) and replacing electrical or wiring seems like it may be complex.
Old Aug 24, 2016 | 04:40 PM
MiniToBe's Avatar
MiniToBe
I think you got a grounding issue. There is a wire connected to the motor mount on the passenger side. Check if the voltage is the same from that end (close to the starter). If the voltage is low, check the wire and or run a new wire to test it out. Basically, doubke check your connections. Use your hands to feel them.
Old Aug 24, 2016 | 05:04 PM
BlwnAway's Avatar
BlwnAway
Did you paint anything in the process of the swap, there can be no paint between the upper motor mount and the ground strap or the block.
Fialee
Mar 18, 2022 06:44 AM
DRoc7822
Feb 11, 2017 08:39 AM
ShadyCoop
Mar 31, 2016 02:31 PM
davidg5700
Mar 23, 2016 07:44 AM
Doc Pain
Mar 14, 2016 09:01 AM
