R60 Missing a plug ? Connector
Old Jul 29, 2016 | 09:29 AM
ceddy1031's Avatar
ceddy1031
Hi there, today when I look inside the engine bay to check if any coolant or oil leak, I found this little plug. Is it supposed to connect to somewhere ? Does anyone know where this thing goes ?
Attached Thumbnails Missing a plug ?  Connector-20160728_191554.jpg   Missing a plug ?  Connector-20160728_191608.jpg
Old Jul 29, 2016 | 09:32 AM
MarioKart's Avatar
MarioKart
Vendor
I thought the same thing, but on the N18 motors it's supposed to look like that. You are fine.
mQubed Motorsport, Manic Tuning Dealer
Old Jul 29, 2016 | 09:38 AM
ceddy1031's Avatar
ceddy1031
Thanks. I feel much better now. BTW my car recently throw me a check engine light. Sometimes it will turn off itself. But it comes back on. The code saids P0597 $07E8 Generic - Thermostat Heater Control Circuit/Open.
I wonder if that will cause damage to the car if I don't fix it ? I tested the heat and it is running fine.
Old Jul 29, 2016 | 02:15 PM
cccplus's Avatar
cccplus
Did you get your thermostat replace? That 'little plug' is the coolant temp sensor that is now relocated to the new tstat design. That error code is a symptom of tstat going bad and will need to be replaced. If you're under warranty, get it fix asap. If you're out of warranty, in CA, the tstat is covered under emission warranty for 7yrs/70k miles.
Old Jul 29, 2016 | 06:16 PM
ceddy1031's Avatar
ceddy1031
I doubt it though. My car has no more warranty. Is a 2012 model but it has 82,000 miles on it. You think I can still bring it in and see if they will grand me this one.
otfox
Nov 26, 2018 01:08 PM
pfcmooney
Apr 26, 2016 05:01 AM
lasher10
Apr 23, 2016 12:41 PM
MinisWIthAttitude
Apr 22, 2016 04:05 PM
htravolta
Apr 21, 2016 08:19 PM
