Suspension kW v3 dragging parts too much drop
Old Jul 23, 2016 | 09:14 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Anyone run kW v3 with the spring set higher than the max in the install manual? I'm dragging everywhere drags too much. Lots of thread left but I'm almost at max of what the install manual says,. Like 8.5 front and 8.3 rear
Old Jul 25, 2016 | 01:21 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
What do you mean by "dragging?"
Are you scraping the bottom of the car on the ground, or are the tires rubbing the inside of the fender?
Old Jul 25, 2016 | 01:23 PM
MrBlah's Avatar
MrBlah
On gravel it's scraping the ground, the road has a high center I bet I'm an inch lower than my jcw
Old Jul 28, 2016 | 08:31 PM
chudlo's Avatar
chudlo
I just put KW V3s on my 2003 MCS and remember adjusting the spring pretty high, a bit higher than I thought it should go. I don't remember the measurements right now, but I think I was able to raise the car to an inch lower than stock height.
Were are you measuring "Like 8.5 front and 8.3 rear" from?
Old Jul 29, 2016 | 04:34 AM
MrBlah's Avatar
MrBlah
the install directions measure from a point on the bottom of the shocks to the bottom of the spring that's what I was doing.
I have to drive on the edge of the road or I drag parts all over lol, my r53 JCW (with red springs) is almost as bad
quickcoop
Sep 21, 2018 03:40 PM
jerseyclubman
Aug 22, 2018 04:01 PM
JWA
Apr 20, 2016 09:12 AM
Ol' Blue
Apr 13, 2016 03:38 PM
rob76turbo
Apr 8, 2016 12:12 PM
