Suspension How to install Rear Swaybar R52?
Old Aug 3, 2016 | 12:07 AM
Dylan H's Avatar
Dylan H
Has anyone upgraded to a 19mm on a Convertible? I have the shocks removed and the stock swaybar disconnected. I removed the subframe bolts including the "hidden one" in the middle under (through) the heat shield. While prying I can slide the old one out half way and it hits the middle brace. Do I need to remove the whole exhaust?
Thanks folks!
Old Aug 3, 2016 | 07:39 AM
nkfry's Avatar
nkfry
The "spider bracing" needs to be removed as well as the 5 subframe bolts removed. Then you'll need to use a prybar between the body and the subframe to give yourself more room, but you can push it half way through from the passenger side then go to the drivers side and wiggle it out the rest of the way.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
thinkMINI
Detailing 101
27
Feb 22, 2018 04:06 PM
crimson_king
Apr 26, 2016 12:08 AM
lyestille
Apr 22, 2016 04:52 PM
midwestinsocal
Apr 13, 2016 11:40 AM
mcn02
Mar 17, 2016 03:59 PM
