R50/53 P1242
Old Jul 20, 2016 | 01:06 PM
sherman89's Avatar
sherman89
P1242
My CEL lit up with code p1242 which is high pressure on deceleration which I think means a air bypass valve replacement, do other R53 driver concur?
Old Jul 21, 2016 | 02:31 PM
Mini Mania's Avatar
Could be the vacuum tube that connects to the MAP sensor - the fitting at the sensor has been known to get brittle over time and break off. Also could mean bypass valve replacement.
http://new.minimania.com/part/NME760...m-Gen1-R52-r53
Old Jul 22, 2016 | 08:42 AM
sherman89's Avatar
sherman89
Where would I find the vacum tube, I am very new to this mini----I know where the bypass valve is.
Old Jul 22, 2016 | 02:26 PM
Mini Mania's Avatar
MAP Sendor
Hi Sherman!
Here is a diagram that may help. The description says "Attaches to the intake snorkel just downstream from the throttle body."
http://new.minimania.com/part/NME777...m-Gen1-R52-R53
Old Jul 23, 2016 | 01:59 PM
sherman89's Avatar
sherman89
thanks for the info.
Old Jul 28, 2016 | 11:50 AM
sherman89's Avatar
sherman89
I replaced the bpv and cleaned up the throttle body last night then took for a run----everything seemed fine including the rpm drop between gears---no CEL. Today after a 50 mile run the CEL came back on after a restart and a code of 1242 so the problem has not been remedied. I did check the vacuum line and all seemed well. The MAP sensor is new---is there anything else that can be wrong??? Where does the vacuum line normally crack? The line I checked is much longer than the one shown in the graphic.
Enjoytheride
May 6, 2016 01:34 PM
GrayGhost
Apr 16, 2016 05:36 PM
Mar 24, 2016 11:31 AM
JWA
Mar 20, 2016 06:40 AM
billyg
Sep 22, 2002 04:36 PM
