abs, asc, flat tire, monitor, brake pad lights on
Old Jul 11, 2016 | 08:37 AM
donmack's Avatar
donmack
2004 cooper, replaced left strut mount and both front control arms bushings (which are on the rear of the control arm) alined toe in/out to 0'0". removed and cut the wire to the brake pad sensor, (left front and rear right) tied brake pad wires together. pulled the car of the lift and now i have abs, asc, brake pad, flat tire monitor lights all on. what the heck, i didnt do any thing with the braking system, tire presure. the dsc switch wont turn off the asc light. check all the wire cant find any bad wiring. any ideas on what to do next?
Old Jul 11, 2016 | 08:41 AM
nkfry's Avatar
nkfry
You most likely need a wheel speed sensor, if it wasn't left unplugged that is..
You'll need to find someone with a scan tool and see which of the wheel speed sensors is faulty or non responsive.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jul 11, 2016 | 08:53 AM
donmack's Avatar
donmack
didnt have the problem before changing the bushing, why would a speed sensor go bad after the bushing change, didnt unplug it during the work. I have heard that speed sensor can be test with a volt meter but i dont know what ohm reading should i see ?
Old Jul 11, 2016 | 08:56 AM
nkfry's Avatar
nkfry
The sensor is a hall effect sensor, ohm reading isn't going to tell you much, you need to either run an oscilliscope or scan tool on it.
The fact that you had the left front corner apart to do the strut mount would lead me to start diagnostic with the left front sensor.
Phone:586-792-6464
Old Jul 11, 2016 | 09:21 AM
donmack's Avatar
donmack
ok, i have a obd scanner ill try scanning and see what comes up. will post results. thanks
Old Jul 11, 2016 | 09:42 AM
donmack's Avatar
donmack
connected obd ll "no faults detected"
Old Jul 11, 2016 | 10:00 AM
nkfry's Avatar
nkfry
You need a quality scan tool, generic tools are fairly useless.
The lights are on for a wheel speed fault, whether you have a faulty sensor or damaged the tone ring on the wheel bearings.
Phone:586-792-6464
Old Jul 11, 2016 | 10:04 AM
donmack's Avatar
donmack
just learned my actron cp9145 does not read abs codes.
boydie
Mar 3, 2019 10:20 AM
padman12
Apr 28, 2016 09:15 AM
MrBlah
Suspension
Mar 23, 2016 03:17 AM
Smitha6
Suspension
17
Mar 22, 2016 07:51 PM
JWA
Mar 20, 2016 07:24 AM
