R50/53 R53 ASC EML Service Engine Soon
Old Jun 20, 2016 | 07:26 PM
Cor4eyh's Avatar
Cor4eyh
Was driving my commute to work and there's a couple of pretty large bumps going about 75 mph.
After a bump Service engine soon light, Asc Light then later when it hit Limp mode EML light came on.
Have done a ton of research on this issue some say its throttle body others say its battery and even fewer say its actually the Wiring harness.
My question is has anyone else had this issue? Will the battery really cause all these issues? Is there a "TB Wiring harness" so i'm not replacing the entire wiring harness?
Any help would be most appreciated.
Old Jun 21, 2016 | 07:26 AM
ZippyNH's Avatar
ZippyNH
Till you get the code pulled, it is JUST SPECULATION.
get the code ....
Before then speculation is just that...
The code will lead you down the path on where too look...
Could be 5¢ rubber hose, or a loose wire...
Old Jun 21, 2016 | 07:27 AM
Cor4eyh's Avatar
Cor4eyh
Codes pulled p1226 p1125
Old Jun 21, 2016 | 03:34 PM
HaltCatchFire's Avatar
HaltCatchFire
P1226 Throttle Malfunction (Flap Malfunction)
P1125 Throttle Position Sensor A and B Range/Performance Small Error
This tells me that likely the drive-by-wire can't read the pots to close the feedback loop. You'll want to trace the TB harness back for abrasion and remove/clean the connector, to eliminate the easy stuff.
flyjets01
R58 :: Coupé Talk (2012+)
Apr 7, 2016 01:22 PM
clevelandrum
Apr 4, 2016 08:15 AM
bneer
Mar 29, 2016 12:30 PM
brokencooper
24
Mar 29, 2016 10:15 AM
dm33
Mar 25, 2016 04:56 AM
