Navigation & Audio Check engine lights displayed in nav?
Old Jun 18, 2016 | 11:49 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I'm retrofitting chrono rpm/speed onto my 2006, are there any check engine/error lights displayed on the factory navigation?
My plan was to only use the bezel for fuel level, and put my tablet where the factory display would be but I dont want to miss out on any error lights
I already have a separate headunit for audio/bluetooth
Old Jun 18, 2016 | 11:55 AM
ZippyNH's Avatar
ZippyNH
You need ALL parts from a chrono car....warning lights are split between all 3.
Old Jun 18, 2016 | 11:59 AM
MrBlah's Avatar
MrBlah
on a factory nav car, what errors are displayed in the nav unit itself? I'm not sure how the wiring is setup on these yet, just started to dig
chrono gauges will be here in a few days
Old Jun 18, 2016 | 12:01 PM
MrBlah's Avatar
MrBlah
ahh I think I figured it out, there's a display above the nav lcd too, I plan on retaining that and only replacing the nav lcd itself
Old Jun 18, 2016 | 12:58 PM
ZippyNH's Avatar
ZippyNH
The positions of the lights are different....
You need too swap all 3.
Only swapping 2 will leave you missing some and having some doubles...when programmed, it will not work...just cause the sizes are the same does not mean they are interchangeable.
Old Jun 18, 2016 | 01:03 PM
MrBlah's Avatar
MrBlah
what do you mean all 3? I thought the nav computer itself was unrelated to the vin encoding, the housing around it however, does have a vin & miles encoded onto it, and is coded to work with chrono gauges
only problem I might have, the vin/miles may still be unchangable on these center units, checking with the bmw nav forums
Old Jun 18, 2016 | 01:09 PM
ZippyNH's Avatar
ZippyNH
Speedo, tachometer, AND CENTER unit...ecu might be needed and BCM, but there is a place in Canada that can recode them, even maybe one of the guys down at helix.
Just swapping the center unit is not enough.....while the speedo and tach LOOKS the same on the non-nac cars, the warning light positions are different .
You say you are doing a chrono pack car. But saving the NAV unit?
Old Jun 18, 2016 | 01:20 PM
MrBlah's Avatar
MrBlah
I was gonna swap all of that. Single to dual gauge and center to nav
Old Jun 18, 2016 | 02:42 PM
RB-MINI's Avatar
RB-MINI
I think the issue is the dual gauge pod is slightly different between the Chrono pack and NAV, so you need to make sure you get a NAV dual gauge pod to match your NAV center cluster if not buying as a set.
Old Jun 18, 2016 | 06:51 PM
MrBlah's Avatar
MrBlah
realoem shows them as the same
911***
Apr 28, 2016 07:51 AM
Mr. Krisztian
Apr 25, 2016 07:15 PM
jasonl
R55 :: Clubman Talk (2008+)
11
Apr 23, 2016 06:07 PM
LTNMUP
Apr 11, 2016 12:34 PM
joe29
Mar 30, 2016 02:13 PM
