Suspension Ready to replace/upgrade my R53 suspension, am I missing anything?
Old Jun 7, 2016 | 08:10 AM
navybsn's Avatar
navybsn
Ok, after months of research and decision making about what my goals are with the car, I'm ready to pull the trigger on the parts. I just want to check and make sure I have everything on hand so I can get it all done at once.
Here's what I have on hand:
Adjustable rear links
Koni Orange rear shocks
Here's the rest of what I have on the list:
Ireland Engineering Adjustable CamberPlates $275
Vorshlag Camber Plates $440
TSW Rear Swaybar 19mm $180
TSW MINI Performance Springs $230
Koni Street STR.T Orange Shocks $312 (front pair)
Powerflex Rear Upper Shock Mount Bushings $70
PowerflexRear Trailing Arm $75
Powerflex Front Control Arm PolyurethaneBushing kit $187 (w/brackets)
Powerflex Front Sway Bar Bushings $54
I'm still undecided on which camber plates to go with, but I'm leaning towards the IE plates as this is a daily driver and not a track car. What if anything am I missing parts wise? Do I replace the front strut tops with the camber plates? I think I can reuse the factory bump stops and dust boots. Anything else worth doing while I'm in there (I've already done the engine mounts)?
Don
Old Jun 7, 2016 | 05:02 PM
Mini Mania's Avatar
R53 Suspension
Don
Hi Navy! Great list, very ambitious. Not sure you need the camber plates if not a track car, but that's up to you. You may wish to cross reference your shopping list with our performance upgrade page and our R53 suspension page. I also have an R53 so would love progress reports/pix.
http://new.minimania.com/June_is_Per..._Upgrade_Event
Here is some great suspension background info:
http://new.minimania.com/Search_Results/suspension/All
P.S. I'm guessing you are in the Navy? Where stationed?
Old Jun 7, 2016 | 06:13 PM
navybsn's Avatar
navybsn
Actually retired a few years ago. We were stationed pretty much anywhere you can think of. A great experience!
As for the camber plates, I was under the impression you had to use them with lowering springs, even mild ones like the TSW springs.
Old Jun 8, 2016 | 01:17 PM
Mini Mania's Avatar
Camber Plates
Some good background info here:
http://new.minimania.com/part/NMS521...n1-R53-R52-R50
Plus articles on camber adjustment, plates and autocrossing.
Old Jun 9, 2016 | 02:09 PM
Mini Mania's Avatar
R53 Suspension
The lowering springs will affect the camber on the rear, but not the front, so the front camber plates are not 'required' when lowering.
The front MacPherson struts maintain camber even when lowered.
However, the rear camber will change with the independent rear suspension when the car is lowered and the adjustable rear control arms are necessary to correct the rear camber.
Hope this helps!
quickcoop
Dec 4, 2020 09:05 AM
paulsminis
Suspension
17
Dec 7, 2017 10:17 AM
Mini_Vinnie
Suspension
19
Aug 24, 2016 11:19 AM
03cooperr53
Suspension
Mar 17, 2016 01:01 AM
PelicanParts.com
Mar 16, 2016 12:37 PM
