R50/53 r53 Trifecta caused only by speed sensors?
Old Jun 4, 2016 | 11:46 AM
SooperCoopers's Avatar
SooperCoopers
Hello,
I have a 2003 R53 and I am currently getting the "trifecta" illuminating on the dash (ABS light, DSC, and tire pressure).
I have looked at all 4 wheel speed sensors.
I looked at the sensors with a scope: all 4 wheel speed sensors are getting about 13V DC, Has a 0.2 V square wave on the output when rotating each tire.
Now some of the sensors on the car may be aftermarket (not OEM). My question is, could anything else be causing this "trifecta" illumination?
Old Jun 4, 2016 | 08:06 PM
SooperCoopers
As an update: The three lights only illuminate if I reach speeds in excess of 10mph. If i drive constantly below 10mph, none of the three lights will turn on.. .does this point towards anything?
Old Jun 8, 2016 | 01:12 PM
gsfent's Avatar
gsfent
Not sure about the MC, but in BMW's of similar vintage, those symptoms often point to a bad ABS module if all the wheel sensors check out. Solder joints go bad over time. Repair is about $200.
Regards,
Jerry
Old Jun 9, 2016 | 01:46 PM
nkfry's Avatar
nkfry
Wheel speed sensors or wheel bearings are the usual cause of the trifecta if you have already verified that there are no wiring issues, or exposed wiring.
My car had an occasional DSC/TPMS light with no codes stored as to which location, and it would go out whenever it wanted, turned out the problem was the tone ring on the LF wheel speed sensor.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
afadeev
Mar 27, 2016 10:14 AM
iclancy82
Mar 25, 2016 08:37 AM
SmurfNinja
Mar 23, 2016 03:56 AM
HaveATank
Mar 21, 2016 08:11 PM
Turbo R53
Mar 18, 2016 01:33 PM
