R50/53 A arm bushing replacement
Old May 31, 2016 | 12:32 PM
98oilhead's Avatar
98oilhead
I'm a reasonably competent mechanic. Need to replace the a arm bushing..I have the complete assm. I have a Bentley manual that makes the job "seem' pretty straight forward. I will remove the a arm..Bentley sez..special tools..needed? How is the bushing assm. removed from the a arm..straight forward? Any addl. "help" will be appreciated
Old May 31, 2016 | 12:36 PM
HaltCatchFire's Avatar
HaltCatchFire
There are a few ways to do this but it depends on what you got. By "complete assm" do you mean you got pre-pressed bushing in the carrier bracket? Poly or OEM?
Old May 31, 2016 | 12:47 PM
98oilhead's Avatar
98oilhead
Complete o.e.m
Old May 31, 2016 | 01:17 PM
HaltCatchFire
I assuming that's pre-pressed like this. You need to lower the subframe and just swap out the brackets. Good tutorials here and here.
You can pull the outer ball joint 13mm bolts instead of popping the taper if you want to avoid using a ball-joint tool.
If you leave the arms on the subframe until it's lowered and you can pull the carrier and arm off together, then pull them apart on the bench. The special tool is for pulling and pushing the bushing to/from the hex shaft of the arm - it's not necessarily needed. A pry bar or heavy screwdriver works fine to get it off - it's rubbery and sticks so it takes a little work. You can use a press or hammer to get the new one on if you're careful.
bahman
Aug 6, 2016 06:43 AM
Themajickman
May 30, 2016 08:10 PM
May 24, 2016 04:27 PM
furnitureman9
How to
May 23, 2016 04:54 PM
Indimanic
May 5, 2016 02:05 PM
