R50/53 Temperature is maxed on start
I just finished putting everything back together in my 2002 R53 after changing the clutch and have an odd problem. When I turn the car on, the engine temperature gauge spikes to maximum. The cooling fans kick on and don't turn off even after the car is turned off (I have to disconnect the battery.) Is there a connector I missed or did I short out a wire somewhere?
Temperature gauge
Though a new and fun problem has arisen where the outside temp sensor will drop to -40, then climb back up. Makes for amusing drives when when climate control switches to heat on a 90° day. (This seems like a loose wire/periodic short.)
Probably damaged the ambient temp sensor that is on long harness and snaps into back of lower grille on driver side.
FYI the one on ebay I purchased by year/make/model even though snapped into connector was not correct part....read wrong. I ended up needing one from dealer. ( not cheap either )
zooberdoober1
Electrical
May 5, 2019 02:12 PM
Drivetrain 2002 MINI standard 5 speed to a 6 speed
Lori Wilson
Mar 30, 2016 11:25 AM
