R50/53 Oil Pump
Old May 23, 2016 | 12:09 PM
shbiv's Avatar
shbiv
Oil Pump
I have a MC40 that I purchased with a blown head due to running low on oil. The bottom end appears to be fine. I decided to also change out the timing chain, etc. I am putting a new crank pulley on but want to get everyone's opinion on when to change out the oil pump. Car only has 67K miles and the oil pump looks fine from a visual inspection. What are your thoughts? Replace the timing cover/oil pump ($250) or not. I have all the various seals/gaskets coming to me. Any way to check the condition of the oil pump?
Old May 23, 2016 | 12:48 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you have the time and money it might not be a bad idea just from a preventative standpoint. I haven't run across many issues with their failures recently, but it's also the thought of "while you're in there" type thing. Maybe some others will pop in with their suggestions on it. Found some info that you can check out here. Good luck!
http://www.pelicanparts.com/catalog/..._pg3.htm#item8
888.280.7799 | 6am - 5pm PST
angeltrain31
Jun 12, 2016 05:58 AM
Repeat_Offender
May 11, 2016 04:44 AM
CLTMinifan
Apr 6, 2016 12:01 PM
Brownshoe
14
Apr 6, 2016 07:31 AM
alexs3d2
Mar 14, 2016 08:35 AM
