R50/53 Fuel Level Indicator
Old May 23, 2016 | 06:52 AM
MazMini's Avatar
MazMini
So I changed out the fuel pump on my R50 and it keeps showing that it is empty however it has fuel in it. I also disconnected the battery for a couple of days and still nothing. I removed the fuel pump last night to see if anything was loose but everything was in tact.. When i moved the lever it did not change on the dash... It was working before I changed the fuel pump.... Any ideas??
Old May 23, 2016 | 07:02 AM
Hello, did you get the right pump , also there are two levels . Left and right side, the other side might be bad.
https://www.ecstuning.com/Mini-2002-Cooper-R50-Base-Coupe-L4_1.6L_W10B16A/Engine/Fuel/2
Old May 23, 2016 | 07:13 AM
MazMini's Avatar
MazMini
Yeah the pump was correct but I missed that there are two levers...
Old May 24, 2016 | 07:29 AM
Yea, there are two. the other ones failed , its in the link above.
Old May 24, 2016 | 07:46 AM
MazMini's Avatar
MazMini
I wonder if something came lose when I was changing the fuel filter...?? I just dont see how it goes bad from sitting... Thanks i will check tomorrow night
Old May 24, 2016 | 08:04 AM
Yea, you might have bumped one of the cables, but sometimes when you touch other parts.
Take it out , move it up and down on the contact, put it back in and hook everything up.
conesmasher
16
Jun 1, 2016 05:30 AM
0ffthehizzy
16
May 31, 2016 03:38 PM
sevin
May 12, 2016 07:42 AM
MiniClubbie
May 8, 2016 08:36 PM
Hyperblue_r50
Tires, Wheels, & Brakes
May 2, 2016 06:53 AM
