R50/53 Software
Old May 22, 2016 | 05:53 AM
mbronsell's Avatar
mbronsell
Software
Hi all
have a odd fault causes EML light and Limp mode
Have normal code reader and also Ebay copy of Delphi
Is there a software out there that will mimic dealer level so i can try and find this fault so far nothing is stored in engine ECU only Faults in ABS ECU
thanks
Old May 22, 2016 | 10:39 AM
ZippyNH's Avatar
ZippyNH
There is a Romanian guy selling a usb-odb2 cable with a pirated copy of dealer software....
Check eBay...his name changes a bit, but a few folks have bought from him ok.
Old May 22, 2016 | 02:50 PM
mbronsell's Avatar
mbronsell
Thanks have found some see how it works
Old May 22, 2016 | 03:14 PM
ZippyNH's Avatar
ZippyNH
Another user just posted a link...let me see if I can find it again...and I post below
Old May 22, 2016 | 03:17 PM
ZippyNH's Avatar
ZippyNH
Originally Posted by David.R53
I've bought from this guy. Still, be careful - I installed it on a junker Win7 laptop I don't use for anything important. Comes with the software and cable. The seller even helped with install problems. Start reading about how to use inpa and dis. This is the dealer software that can do everything ... Even program new keys if you have the patience to learn how.
BMW USB OBD Diagnostic Cable Inpa Ediabas Ncsexpert Dis V57 SSS V32 Progman GT1 | eBay
Here it is...good luck
Old May 22, 2016 | 03:35 PM
slipmagt's Avatar
slipmagt
Holy cow, will that do the customizable stuff like daytime running lights and such?
Dir it says so in the post. My bad.
Old May 22, 2016 | 04:12 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Advocating purchasing pirated software. Really?
Old May 22, 2016 | 04:18 PM
ZippyNH's Avatar
ZippyNH
Sometimes it one of the only ways....
If BMW sold it...this site has an advertisement for pirated BMW have maps...
We have brought it up...but they use a loop hole...say they sell an activation code...which activates a bootleg Map...lol
Old May 22, 2016 | 11:19 PM
mbronsell's Avatar
mbronsell
Thanks i found something similar should arrive next couple of days
Old May 23, 2016 | 10:44 AM
Originally Posted by mbronsell
Hi all
thanks
Schwaben tool will read all of it and give you MINI level codes that are stored.
https://www.northamericanmotoring.co...d-q-and-a.html
Old May 25, 2016 | 08:40 AM
mbronsell's Avatar
mbronsell
the software i got is the same
BUT with no help to install so you need to be a NASA scientist with a MYT degree that's not me sending it back and have now found the Rumanian guy
Old May 25, 2016 | 06:19 PM
David.R53's Avatar
David.R53
I prefer AutoEnginuity software myself. Fully supported, not bootleg, about $400 between the proline connector and the BMW-specific extensions. Does a lot. Will reset adaptations, reads freeze-frame data stored with codes, shows live sensor data. You can not use it to code options like lights though.
But they don't offer every feature like coding keys. And my local dealers are soulless rascals who charge 20-40% over list for parts, so I stopped going there, which leaves me looking to eBay for the not-sold-to-owners- proprietary software needed to keep my bought-and-paid-for car functioning.
Old May 25, 2016 | 11:27 PM
mbronsell's Avatar
mbronsell
sort of on the trail now managed to get a code P1570 doesnt really give you much of a clue when you look it up
infact makes you feel more irritated its like help no help from the code feel like im going round in circles
Old May 26, 2016 | 07:45 AM
can u see any stored codes ?
Old May 26, 2016 | 08:24 AM
ZippyNH's Avatar
ZippyNH
Well....my goto list doesn't have a 1570
P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1
P1560 "B" Camshaft Position Actuator Control Open Circuit Bank 1
P1564 Control Module Selection
P1565 "B" Camshaft Position Actuator Control Open Circuit Bank 1
P1569 "A" Camshaft Position Actuator Control Open Circuit Bank 2
P1580 Throttle Valve Mechanically Stuck
P1581 "B" Camshaft Position Actuator Control Open Circuit Bank 2
And tools are just that..tools...not a instruction book or how to guide...
They help you diagnose stuff...
Then you must use knowledge to determine the issue....rarely is it one to one relationship codes to parts to fix stuff, as the issue can be upstream or downstream of the sensor.
R53driver19
Dec 21, 2017 04:10 PM
twoj's
Dec 10, 2016 01:48 PM
zamzam
Oct 4, 2016 10:26 AM
VYPUR
29
May 6, 2016 02:29 PM
Ken Grimm
Apr 23, 2016 02:48 PM
