R50/53 Ignition switch/key
Old May 7, 2016 | 08:44 PM
pillagethesound's Avatar
pillagethesound
Ignition switch/key
So the lock button on my key has fallen off and now I am stuck locking my car with the key instead of the button. After the $250 quote for key and programming, I was looking into buying a whole ignition switch with key used on eBay. If I do this and replace the whole thing, does the key still need to be programmed or is it good to go since the used switch and key match?
Old May 7, 2016 | 09:17 PM
Fly'n Brick's Avatar
Fly'n Brick
Here we go again. First, no information about what year and model the key goes to. DO NOT waste your time with ebay keys!! There is a multitude of threads and posts decrying the wasted time, money and effort on those things. The key is programmed to the car's VIN which can only be done through MINI. Also, $250 is pretty high for a key. I replaced one just last year and it was only $150 thru the dealership.
Fax or email a copy of your registration and DL to the dealership and they'll get the ball rolling.
Old May 7, 2016 | 09:58 PM
rkw's Avatar
rkw
Member valvashon offers a key repair service: https://www.northamericanmotoring.co...rbishment.html
Old May 8, 2016 | 06:43 AM
Fly'n Brick
Yea, I'd forgotten about him but he's mostly 1st gen if I recollect. Our OP doesn't provide a clue as to what model he's working on.
Old May 8, 2016 | 07:04 AM
pillagethesound
Its is a 2004 Cooper S. I posted this in the first gen section thinking that provided the information. I'm not talking just the key, I'm asking the key and the ignition module together. I was quoted at the dealer $175 for the key and $75 for programming. Hence the $250 price tag. Replacing the entire ignition module with matching key on eBay ball parks between $75-100. But my question was if doing it this way, key and module, would bypass the need for programming.
Old May 8, 2016 | 07:05 AM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Fly'n Brick
...DO NOT waste your time with ebay keys!! ...
Let's be clear.
If you have a key that a button has fallen off of and only needs refurbishment, then the eBay key replacement cases are perfect. I would recommend going to a switchblade while you're at it but either way, moving your parts from the old key to the new one is simple. And that thread has ALL the information you need.
But if you don't want to do it yourself, Val can hook you right up.
It's not helpful to make blanket statements. But you are correct in that if you want an "extra" key or you lost yours, getting a replacement from the dealer may be your only option OTOH, some locksmiths may also have the right equipment.
///Rich
Old May 8, 2016 | 05:52 PM
rkw's Avatar
rkw
It's the EWS module that's paired with the immobilizer chip on the key, not the ignition switch itself. Besides, if you replace the key and ignition switch, you'll also want to re-key the physical door lock. Also the locking system (doors and remote) operates separately from the ignition immobilizer and you'll have to reprogram the remote anyway.
Michael Nicely
Aug 1, 2016 10:31 AM
noladude70001
Apr 19, 2016 02:07 PM
twoj's
Apr 14, 2016 01:14 PM
Cobrasix
Apr 14, 2016 01:45 AM
Blueberry1980
Apr 11, 2016 09:40 PM
