R50/53 Inexpensive fix
Old May 2, 2016 | 08:22 AM
buzzsaw's Avatar
buzzsaw
Inexpensive fix
. Found this link that may help those with the problem: http://www.minitorque.com/forum/f26/r53-drain-back-plunger-$12-fix-119169/
The part number is: Dorman OE Solutions 904-261-oil drain back valve at Oreilly parts
Old May 2, 2016 | 10:19 AM
ZippyNH's Avatar
ZippyNH
R53 drain back plunger $12 fix!
Ok guys, new to the site and new to the r53. I bought an 03 r53 with 141k miles a few weeks back for 2k. It needed a new throttle body so i bought it and changed it out and it has run like a champ. Started some mild mods to have some more fun. Msd ignition coil, vms plug wires, 380cc injectors, aem intake, and 1 step colder plugs to compliment the 15% pulley that im going to do. While i was changing out all of these parts, i decided to do an oil change.... Literally had oil draining as i was installing the new parts. Got it all back together and filled with fresh oil, went to clean out the filter housing before installing the cap and filter and guess what ??!! Found plastic pieces and 2 springs sitting inside the housing. Got it all cleared out and let the car sit for 2 days as i tried to call every mini parts specialty shop and salvage yard near me out of desperation. I ordered a new housing from WMW FOR $361 shipped. It was a tough pill to swallow but it was my only option.... IS WHAT I WAS TOLD. After doing some searching for drian back plungers and how they work, what cars use them and seeing that these damn things break all the time, i found what i was looking for. The 6.0 ford powerstroke uses a very similar design. Funny cuz i own one too, just my luck. Found the part number and oreilly carries a dorman version. Picked it up for $12 and compared it to the pieces that i had and it was too close not to give it a shot. Very similar design but the 1" wide spring that was original to the mini plunger was longer than the new dorman one . Installed the plunger with the mini spring and it fit just like how the pictures show the original plunger. Started the car with no issues and gave it some very spirited passes down some curvy roads just to be sure. No issues and no oil pressure light so far. Fingers crossed but I think it will do the job. Not sure yet what to do when the new housing comes in next week.... Hope this helps!
More info...its a fix for the filter housing drain back....
Turboed
Suspension
Apr 10, 2016 05:41 AM
iamerebus
Mar 28, 2016 07:00 PM
Bosevii501
Mar 18, 2016 08:01 AM
KerMini
Dec 25, 2003 10:21 AM
