Navigation & Audio retrofit Harman Kardon in an R56
Old Apr 29, 2016 | 12:13 PM
John_theCapn's Avatar
John_theCapn
First, let me say thanks to all for the knowledge that is accessible here. It has helped me to retrofit and code the Bluetooth kit, Sirius and IBOC/HDRadio modules in my newly acquired MINI R56.
So, here's the backstory, bear with me here.... If you don't want to read skip down to the ------------------
I have an '06 R53 that I bought new. It had all the options that I wanted at the time, so I never got into coding; just mods, repairs, etc., so I'm fairly familiar with MINIs in general by doing all kinds of mechanical work. I actually worked part time in a performance shop. But I digress.
A few months ago, I was presented with a deal on an '07 R56 S with a blown engine. I bought it and have been rebuilding, updating, etc.
Here is where I am at and what is relevant to this forum.
I retrofitted the modules mentioned above and have them all working. No problems.
The problem that I am having now is the HK amp isn't outputting sound.
I know that this is a touchy subject as the wiring harness isn't there with the car not having the HiFi already. I'm ambitious, so that's why I'm here looking for help.
What I have done so far.... first, I updated the VO in CAS/FRM to $674, and defaulted CAS FRM RAD2.
Do I need to remove any option codes??
I have ran all 8 wires from the HU back to the amp. Then all 8 back to the front and tied into the existing speaker leads. (I know not optimal, but...)
To get switched power to the amp, I tapped onto F6 in the JBE (A4010 fuse block), passenger side foot well.
I have also tied into the CAN bus by piggy-backing onto pins 45 and 46 on the FRM/footwell module; driver's side. This goes to pins 18 and 19 on the HK amp. This, as I understand, is where the "control" of the amp comes in. Correct me if I am wrong.
I know that there is signal(sound) getting back to the amp. I know that it seems to be turning on, but that's it.
Do I get the CAN link somewhere else? The only other place that I can find in the Bentley book is pins 13 and 26 (or 5 and 6, for the other side of the instruments) on the JBE itself.
The only other thing that I can think of is to update the software version on the RAD2 (or other) module. How would I go about doing that? WinKFP? Other? Would it be better to get an updated/newer radio HU from an '09+ model?
Help?!?!
Thanks!
Attached Thumbnails retrofit Harman Kardon in an R56-0429160848a.jpg   retrofit Harman Kardon in an R56-0429160848b.jpg   retrofit Harman Kardon in an R56-0429160848c.jpg
Old May 4, 2016 | 12:23 PM
John_theCapn
Can someone confirm their VO option list for me? I think I may have stumbled upon something. Do you have $6FC or $6FD in for the radio option. This is if you have HiFi, or HK. Either setup should have one or the other. I think.
Old May 18, 2016 | 05:41 PM
John_theCapn
I think I may have found the issue.
Unbeknownst to me, the radio is not original.
This is what's pulled from INPA, etc. : 63 MASK/CCC OKAY 3455263 TU67411 20.08.2009
I can't get it to accept an update in WinKFP because is says it's not in the manufacture data. What doesn't make sense is that the last 7 show it being in a June of '08 build R56. I have the latest daten that I could find, v53.3, Aug of '14.
Do I need to downgrade my daten files to be able to handle the older rad/cc/mask module? Does anyone know of a way to overwrite the Boost radio with another ZUSB file?
Old May 19, 2016 | 07:15 AM
John_theCapn
OK, I was able to get the radio to accept a ZUSB update. It went from 3455263 to 3456337.
It still shows as MASK/CCC tough.
More info.... I was able to lookup the VIN and the car it came from was equipped with the HiFi system. It should have worked from the beginning (unless I just don't understand this at all).
Also, the output from INPA (complete) is here:
V E H I C L E D A T A
Date: 18.05.2016 18:57:55
Model: R56
VIN: WMWMF73567TL87482
I-step plant: R056-07-03-515
I-step dealer: R056-10-03-503
I-step backup: R056-07-12-521
Model: R56_
Model code: MF73
Coding date: 0909
Paint code: 0A63
Upholstery code: FKE3
Nos. of SA: 39
1CA 214 226 249 255 2RG 2TA 329 383 441
450 481 493 4AA 4AU 4BB 4BD 4UF 520 530
550 563 5DD 645 653 655 674 693 694 6FC
6ND 736 842 845 853 876 8SM 8SP 925
Nos. of E word: 2
A070 EWS4
Nos. of HO word: 1
SDAR
AND-----------------------
U S E R I N F O R M A T I O N F I E L D
Date: 18.05.2016 18:03:00
Model: R56
Scope: all control module
JobStatus: OKAY
Quantity: 17
ADR Gen. name JobStatus
92 VIRTSG92 ERROR_ECU_SERVICE_NOT_SUPPORTED
ADR Gen. name JobStatus ZB No. VIN No. Date
00 SPEG OKAY 3450824 0000000 07.03.2007
01 MRS OKAY 3428715 ÿÿÿÿÿÿÿ 06.03.2007
02 SZL OKAY 3451901 TL87482 04.03.2008
12 DME/DDE OKAY 7608280 TL87482 16.06.2010
29 DSC OKAY 6785682 TL87482 04.03.2008
30 EPS OKAY 6783551 TL87482 04.03.2008
37 AMP OKAY 9296630 ÿÿÿÿÿÿÿ 05.04.2013
40 CAS OKAY 9226238 TL87482 16.06.2010
53 IBOC OKAY 9119363 ÿÿÿÿÿÿÿ 19.04.2007
54 RADIO OKAY 9142852 TL87482 04.03.2008
55 ISPB OKAY 9224674 ÿÿÿÿÿÿÿ 08.10.2009
60 KOMBI OKAY 9201394 TL87482 16.06.2010
62 MOSTGW OKAY 9199438 TU67411 20.08.2009
72 FRM OKAY 3452092 TL87482 04.03.2008
78 KLIMA OKAY 3454080 TL87482 16.06.2010
I have updated the AMP, SPEG and MRS, so they all match. This also confirms that the system is seeing the amp.
I'm working on getting the ISPB updated as soon as I can find the ZUSB from the E60 datens. Surprisingly it works as-is and did from the beginning of all this.
Does no one have any ideas or things to try?
My next step...... I have ordered another Boost radio from a breaker's yard, so hopefully I can get this to work. Its part number is: 65123455539 and should fall into the year range that the HK was offered. At least it should.
One last question. What should the MINI Boost radio show up as in the UIF pull? RAD2/2RAD?
Old Jun 3, 2016 | 07:42 AM
John_theCapn
For those that want to know, I figured out what my problem here was.
The single black turn-on (amp pin 10) was bad. I re-ran a new one and all is good. What was really throwing me off was the amp was getting power, it was being seen on the bus, but no sound was coming out. This explains it. Now I can stop beating my head on the wall and finish this project.
So, if you want to retrofit a HiFi or HK amp to a base radio equipped car, you can do it.
It's not that difficult, but it does take some time and you have to wire everything up and code it in.
quickcoop
Dec 4, 2020 09:05 AM
aparrado
Jan 7, 2019 08:30 AM
johntotah94
Jan 20, 2018 11:09 PM
xcountryfun@gmail.com
Aug 16, 2016 03:17 PM
spikeyadrian
Mar 18, 2016 07:24 AM
