R50/53 Parts to Replace During Clutch Job
Old Apr 24, 2016 | 08:50 AM
SooperCoopers's Avatar
SooperCoopers
Hello everyone,
I am planning to do another clutch job (with single mass flywheel, new flywheel bolts, throw out bearing of course) in about two weeks, and I would like some advice as to which parts I should replace while doing this...
Here is what I have thought of so far:
Input Shaft Seal
Rear Main Seal
Clutch Fork Bushings
Throw Out Bearing Guide tube (necessary?)
Axle Shaft Seal
Anything I am missing, or really dont need above? I just want to tackle all of the (relatively) cheap stuff while I have the bell housing off to maximize the efficiency of this project
Also, I saw this gearbox seal rebuild kit on Ebay, and was curious if anyone has had experience with this? Would anyone recommend buying this kit?
http://www.ebay.com/itm/Mini-Cooper-S-R50-R52-R53-GS6-85-gearbox-bearing-oil-seal-rebuild-kit-/111669123684?_trksid=p2141725.m3641.l6368
Thanks for your help!
Old Apr 25, 2016 | 05:45 AM
Wertles's Avatar
Wertles
This is also a great time for an oil pan gasket, oil filter housing gasket, oil cooler o-rings, crank position o ring, oil dipstick o ring, valve cover gasket, serpentine belt, water pump o ring (consider changing water pump depending on your mileage) and change the oil in your supercharger. This will add about $100 to your job but you will not have to worry about any leaks for a long time. I just did this exact job last weekend and was amazed at how hard the gaskets were with only 45,000 miles (but 12 years old).
Old Apr 25, 2016 | 11:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'd suggest checking out our clutch super kits HERE. We have listed what comes in the kit , which is just about everything you'll want to replace while you're in there for the job. Let me know if you have any questions about them.
888.280.7799 | 6am - 5pm PST
Old Apr 25, 2016 | 07:16 PM
navybsn's Avatar
navybsn
I would add upgrading to urethane mounts, power steering hoses, and order a second rear main seal. You don't want to find yourself at 2:00 on a Saturday with a seal you've fudged up and have to scramble madly to source one locally. Not that that has ever happened to me they're only $12-13. Good insurance if you ask me.
Old Apr 25, 2016 | 11:47 PM
MiniKar's Avatar
MiniKar
Write to Way, at Way Motor Works and ask him.
He not only sells the parts but does the service end also.
Old Apr 26, 2016 | 07:13 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Typically we just do the guide tube, rear main, and input shaft seals. If the car hasn't had powerflex control arm bushings installed it is also a great time to do it.
You can also put the powerflex gearbox bushing in at the same time.
http://www.waymotorworks.com/gear-bo...yurethane.html
Otherwise if it isn't broke don't fix it.
We offer the seals and tube as add on to our valeo kit
http://www.waymotorworks.com/valeo-c...l-kit-r53.html
Mrdi
25
Oct 20, 2016 06:21 PM
fjohn624
Jul 20, 2016 08:30 PM
Mister
Apr 18, 2016 05:20 AM
MiniVoid
Apr 2, 2016 05:44 PM
AlphaQuad
Mar 29, 2016 07:07 PM
