R50/53 Mini Cooper s cold air intake
Old Apr 7, 2016 | 04:12 AM
Russter500's Avatar
Russter500
If I bought a cold air intake for my Mini Cooper s will it make it run lean or will the computer be able to counter it with more fuel? I'm thinkin of upgrading the injectors later to the jcw size which I believe was 380cc. Thanks!
Old Apr 7, 2016 | 06:37 AM
Ol' Blue's Avatar
Ol' Blue
The computers in these cars seem to be pretty adaptive so you can do a decent amount of mods before needing a tune. The basics such as pulley, intake, and exhaust will give you no trouble at all.
Old Apr 7, 2016 | 07:03 AM
It will be fine on most intakes , what do you have in mind ?
Old Apr 7, 2016 | 07:15 AM
Russter500's Avatar
Russter500
I'm not exactly sure I'm trying to get something that's on the cheaper end but still really good. Any recommendations?
Old Apr 7, 2016 | 07:56 AM
MINIAC's Avatar
MINIAC
If you haven't already done so, your first performance mod should be a supercharger reduction pulley, smaller drive belt and one-step colder spark plugs.
Old Apr 7, 2016 | 07:58 AM
Cheaper end : not really CAI> https://www.ecstuning.com/Mini-2005-...Engine/Intake/
HSMINI + RD-0720
Others: https://www.ecstuning.com/Mini-2005-...Engine/Intake/
Old Apr 7, 2016 | 12:21 PM
Unbreakable Lump's Avatar
Unbreakable Lump
It won't run lean and you don't need new injectors. The fueling is based on the MAP sensor input. A new CAI might increase MAP slightly, but the ECU is calibrated for MAP values much higher than what a stock package can deliver, which is why a re-map and injectors aren't even needed with a 17% pulley.
Old Apr 7, 2016 | 01:57 PM
sevin's Avatar
sevin
Do you have any numbers or data on the ECU airflow calibrations? At what point would you need bigger injectors or a re-map?
Old Apr 7, 2016 | 06:01 PM
Russter500's Avatar
Russter500
Oh okay thanks I didn't know that. All though I did hear some people talking about when you install a reduced pulley, that you need to upgrade your injectors to the 380cc set. They were saying at higher rpm it will lean out slightly, not sure about this though
Accessory Products
Feb 21, 2016 07:23 PM
d00lindalton
Feb 20, 2016 12:54 PM
Feb 19, 2016 02:52 PM
Feb 18, 2016 10:47 AM
Austinsynthetics
Feb 17, 2016 11:09 PM
