R50/53 Mini code reader advice
Old Apr 6, 2016 | 12:45 PM
willy-mini's Avatar
willy-mini
Hello all. I am looking for a relatively inexpensive code reader to read the mini engine fault codes. I have been experiencing issues with my r53 going into limp mode and sometimes not starting properly after many many attempts. The OBDII gives a p0229 "throttle position sensor" code but thats very general. Anyone know of a good code reader that will go into more detail and isnt going to break the bank? Dealer and most mini service are charging $140 avg to run a diagnostic on the car.
Old Apr 6, 2016 | 12:50 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
One of my local indy shops charges 50 for a diagnosis read. Vendor on here ECS had been selling a new device you might want to read up on.
Old Apr 6, 2016 | 12:53 PM
willy-mini's Avatar
willy-mini
$50 sounds about reasonable for a diagnostic. Whereabouts are you located? Anymore infro on the device you are talking about?
Old Apr 6, 2016 | 12:56 PM
Minnie.the.Moocher
Portland Or
https://www.ecstuning.com/Search/Sit...tic/ES2975699/
Old Apr 6, 2016 | 01:22 PM
Saves a trip:
Reviews here on what it will do.
https://www.northamericanmotoring.co...d-q-and-a.html
Old Apr 7, 2016 | 12:24 PM
willy-mini's Avatar
willy-mini
+1
Saves a trip:
Hey ECS, id really be interested in this code reader if it works as an obdII that i can also use to diagnose some of my jeep issues. Is this only a bmw/mini code reader? Does it only work with the vehicle which vin you enter in the system? Im interested, just not sure how much longer i will own the mini. May need to move into a work truck soon.
Old Apr 7, 2016 | 12:30 PM
You will select the OBD2 icon( on the left) and it will reads all the Jeep codes. Then go to foxwell site after you register the scan tool ( on it ) and you can get the Jeep updates.
The unit comes programmed from the factory with the BMW / MINI / RR specific software which is the icon on the center left.
joelmz
Jan 12, 2017 09:48 PM
mremg
Apr 13, 2016 08:25 AM
zkrpS
Feb 23, 2016 10:31 AM
Feb 22, 2016 02:54 PM
Feb 16, 2016 08:26 AM
