Squealing windows
Old Aug 30, 2004 | 12:44 PM
RHT3's Avatar
RHT3
Squealing windows
My '03 Cooper S's windows squeal [since new] when outside temp is over 70F. Sounds like seals against glass, but not like a window regulator chatter. The dealership suggested a BMW rubber conditioner.
Any thoughts? MINI USA will probably blame my pulley or lowering springs.
Old Aug 30, 2004 | 01:08 PM
Bisch's Avatar
Bisch
My tracks had to be replaced. Same problem. The tech said he averages 1 set per day! I watched him do the job...you could have blindfolded him.
Old Aug 30, 2004 | 01:11 PM
chollomo's Avatar
chollomo
mine have squealed twice on me and but it looks liek the secodn tiem it work ed permently.
the windows lubrication ahd all dried up in my door, which is a very rare thign to thappen, especailly in a new car.. so they re lubricated it twice. and now it's doing great no more squeals.
if your still under warrenty the deaelr shoudl haev to fix this for free. if not a qualified autobody store or any reparis man shoudl be abel to lubricated for very cheap.
Old Aug 30, 2004 | 01:16 PM
Tüls's Avatar
Tüls
Turbius Maximus
Mine too...especially out here in AZ it's been over 70 for sure since I got hte car...try 110...LOL...no biggie though..dealer said it happens and they'll be happy to fix it...just make an appointment
Old Aug 30, 2004 | 01:22 PM
RHT3's Avatar
RHT3
All feedback is appreciated. Thanks.
Old Aug 30, 2004 | 04:12 PM
ImaVunDerBrah's Avatar
ImaVunDerBrah
Mine squealed and were driving me insane. Took it to the dealer and they replaced the tracks. When they were checking me out she said 'oh, we just went ahead and replaced the tracks' as though it were easier to just do that under warranty than to try to see if it was another issue. Hasn't squealed a day since. Knock on wood....
Old Aug 31, 2004 | 09:39 AM
C4's Avatar
C4
Easy maintenance folks. Get a spray can of "Silicone Lubricant". Carefully spray silicone in all weatherstripping in both front doors with a towel (Apply 2 to 3 coats all around) and then finish off the job with an "Armor-All , Protectant cleaning wipe" to add another nice coat of silicone. Presto it takes care of any squeaking windows or rattling glass against the rubber weatherstripping and door opening frame when the windows are raised.
Old Sep 5, 2004 | 10:58 AM
MINIDean's Avatar
MINIDean
No! Don't spray silicone spray on the rubber! It will just spread all over the glass and it will smear for a very long time. The squeal is from the tracks, not the rubber.
I took my door panels off and spread a little multi-purpose white grease in the tracks. The metal tracks. There are no rubber tracks on MINI windows. After I put some grease in the tracks, I rolled the window up and down to spread it on the rollers and now I have no squeaks or squeals.
Old Sep 5, 2004 | 03:07 PM
namwob's Avatar
namwob
https://www.northamericanmotoring.co...queaky+windows
Put the silicone down and step away from the Mini. Do it yourself and save a trip to the dealership.
Old Sep 5, 2004 | 07:57 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Mine squeal and chatter. At my next service I will be interested to see how my dealer handles the problems.
Old Sep 5, 2004 | 09:12 PM
YELRSUB's Avatar
YELRSUB
Coordinator :: New Mexico MINI Motoring
Dealer fixed under warranty
When I had the '03 Coop in for 25k service, the dealer lubed the window tracks and the squeak's gone. I didn't even have to ask them to do it.
They also fixed the dreaded dash rattle. Seems the fix is just (5 hours quoted time) putting spacers in over the center pin of the dash to lift it some. It raises it in the middle, which means that now the MINI sun shade doesn't fit without serious disturbance to the mirror. Maybe it's a small price to pay. Under certain conditions the dash now buzzes in a new place. Things to watch out for.
Old Sep 11, 2004 | 08:17 AM
MINI-stir's Avatar
MINI-stir
Just curious, but
Perhaps there are different squeaks?
I took my panels off and lubed up the tracks with lots of grease-- no squeaks. Then, a few days later, temps get hot, squeaks return. My brother was able to pull on the door panel (from the inside) while I rolled the windows up and down-- no squeaking. Most of the time, my windows are silent, but when it gets hot out, or if the car has been sitting in the sun for a while, the windows squeak a bit. Perhaps there is some sort of issue with the seals and the glass. I may try to clean/condition the window seals somehow.
Old Sep 11, 2004 | 08:24 AM
C4's Avatar
C4
Not true. I use a terry cotton towel and spray the silicone onto the towel, then on the weatherstripping. So far, the windows have not gotten smeared with silicone.
Having done the Silicone/Armor all wipe remedy has yielded to very quite windows and glass that doesn't rattle or rub over road bumps.
Old Sep 11, 2004 | 08:26 AM
C4's Avatar
C4
I took my panels off and lubed up the tracks with lots of grease-- no squeaks. Then, a few days later, temps get hot, squeaks return. My brother was able to pull on the door panel (form the inside) while I rolled the windows up and down-- no squeaking. Most of the time, my windows are silent, but when it gets hot out, or if the car has been sitting in the sun for a while, the windows squeak a bit. Perhaps there is some sort of issue with the seals and the glass. I may try to clean/condition the window seals somehow.
Use silicone on the rubber weatherstripping that makes contact with the door glass. When the rubber seals get dry, the frameless glass has a nasty tendency to rub and rattle against the weatherstripping. Problem easily solved with a can of Valvoline Silicon Spray and presto.... No more rubbing or rattling from the side glass!
Old Sep 11, 2004 | 01:42 PM
MINI-stir's Avatar
MINI-stir
I'll give it a go. Thanks.
USNAE2
16
Jun 17, 2022 07:17 AM
scfiveo
Sep 27, 2019 02:27 PM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
rt808
Sep 25, 2015 01:59 PM
