R57 aggressive vibration at stop light
Old Apr 1, 2016 | 03:42 PM
Ben.'s Avatar
Ben.
looking for ideas.
new to the mini world just picked up an 09 mini cooper s convertable
While replacing the water pump, noticed the motor mount was cracked( replaced), after driving for about a week i noticed an AGGRESSIVE vibration, only in drive stopped, the harder I push the brake the worse it gets, all other positions purr like a kitten. today I changed the lower torque arm( lower motor mount), no issues for two test drives then picking up kids vibration came back.
again only when stopped in drive when brake applied wheels straight, turning the wheel makes it go away.
has anyone run into this before?
Old Apr 5, 2016 | 11:42 AM
Ben.'s Avatar
Ben.
Go figure, trans mount reported loose by dealer. investigating now, will update further after engine cools
Old Apr 5, 2016 | 01:29 PM
automan21's Avatar
automan21
Make them change all of them just in case.
Old Apr 5, 2016 | 03:37 PM
Ben.'s Avatar
Ben.
Actually kind of interesting, Just had to tighten the nut. ( but I had already replaced the motor mount and added the spacers for the torque arm.) only took 2 mins and a universal.
Should note though if the dealer tells you its loose might be a good idea to ask how loose before you leave, as there was only at most a 16th sticking up above the nut when I got home and about an inch after I tightened it
Old Apr 6, 2016 | 10:35 AM
It does not take much, glad you fixed the issue. Most bolts the last couple turn it what holds things in torque.
Accessory Products
Feb 21, 2016 07:23 PM
Austinsynthetics
Feb 17, 2016 11:09 PM
jpgwinn24
Test Forum
Feb 16, 2016 03:39 PM
Feb 16, 2016 08:26 AM
rchap
Feb 15, 2016 10:19 PM
