R56 Camshaft Position Sensor code P000A
Old Mar 26, 2016 | 04:18 PM
uconnhuskiesfans's Avatar
uconnhuskiesfans
Opinions needed please. Engine light came on. Pulled and cleared the above code. Do I:
a) buy a new sensor (bosch is around $30)
b) wait and see what happens now that I have cleared the code
c) get over to my local shop, something else could be causing the issue
My daughter is taking her driver license road test in 2 weeks in the Mini and i certainly dont want her to get an engine light (murphys law) during the road test.
The engine light has been coming on intermittently. I thought it was the gas cap but now am rethinking that guess.
Old Mar 28, 2016 | 06:22 AM
uconnhuskiesfans
Bueller? Bueller?
Old Mar 28, 2016 | 06:30 AM
1004ron's Avatar
1004ron
Most often its not a bad sensor, and more likely a camshaft position signal out of synch with the crank position signal, possibly due to one of the variable valve timing solenoid/servo valves fouled up.
Are the oil services up to date?
Old Mar 28, 2016 | 07:07 AM
uconnhuskiesfans
had an oil change about 500 miles ago
Old Mar 28, 2016 | 09:33 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P000A 0x287D 'A' Camshaft Position Slow Response (Bank 1).
I'd probably get it checked sooner rather than later. Some info here: https://www.northamericanmotoring.co...on-sensor.html.
888.280.7799 | 6am - 5pm PST
Old Mar 29, 2016 | 04:01 PM
uconnhuskiesfans
thanks. Going in to my local guy for a possible leaking vaccum pump o-ring so going to have them check into this as well.
Old Mar 30, 2016 | 08:12 AM
PelicanParts.com
Vendor
You're welcome. Be sure to report back with his findings. Good luck!
PelicanParts.com
Feb 25, 2016 03:52 PM
Braminator
Test Forum
Feb 22, 2016 06:43 PM
Feb 22, 2016 02:54 PM
jpgwinn24
Test Forum
Feb 16, 2016 03:39 PM
rchap
Feb 15, 2016 10:19 PM
