Pads, rotors and brake fluid recommendations for 05 S
Old Mar 21, 2016 | 08:29 AM
Buggy's Avatar
Buggy
I own a 2005 MINI cooper S with 115,000 easy miles.
Had the brakes done at the dealer at 53,000 miles. Now i'm at 115,000 and it's time for pads, rotors and fluid. I only put on 6,000 miles a year and drive very moderately.
Could anyone recommend parts and where to get them? Don't think I need anything other than OEM aftermarket parts with a good fluid.
Thanks in advance!
Old Mar 21, 2016 | 09:48 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have some great brake overhaul kits here that you can check out: http://www.pelicanparts.com/catalog/..._pg1.htm#item0
They have everything you need to do the job.
For fluid, I recommend ATE Typ200: http://www.pelicanparts.com/cgi-bin/...er=706232-GOLD Great fluid. I run it on the street and for the track. If you plan do to the fluid job yourself, and in the future, I'd recommend possibly looking into a Motive Power bleeder: http://www.pelicanparts.com/catalog/...pg5.htm#item19. They make the job so much easier. We have an article on our site that goes over the process with this if needed. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Mar 22, 2016 | 10:03 AM
sevin's Avatar
sevin
EBC Redstuff pads should be a good fit for you. They are a good performance upgrade, but also keep the dust to a minimum. For rotors, I'd recommend ECS's GEOMET slotted type. I have those on my rear and the GEOMET coating has been holding up well, rain or shine. The slots are really just for show
ATE Typ-200 is kind of the standard for fluid. No reason to get anything else if you're not strictly autocrossing. It is tried and true.
Old Mar 22, 2016 | 02:40 PM
b6cool's Avatar
b6cool
Another thumbs up for redstuff they are really good rotors you can go with ecs or Zimmerman the coating on those are also good. I have combination of stoptech slotted rotors redstuff pads and fresh fluid from pentosin which you can find in local pepboys store. Too me I think slotted is overkill but looks good. Future I will go with wilwood kit since mini brakes suck when you want to stop from 100 mph
Old Mar 22, 2016 | 06:38 PM
sevin's Avatar
sevin
The slotting is a fashion statement in a street car. Let me be clear, slotted/drilled rotors will NOT help you stop faster, they merely help eliminate brake fade caused by pad outgassing. However, this only occurs after repeated hard braking; you will probably never reach the point of outgassing as a spirited driver on the street.
Old Mar 22, 2016 | 08:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For your use I would install our EBC redstuff pads. Better than the stock with lower dust and good price point.
http://www.waymotorworks.com/ebc-red...r50-53-52.html
Then for rotors check out our WMW plain face rotors as they are great high carbon steel, perfect fit, and reliable. We use these in the shop for all our brake jobs we do.
http://www.waymotorworks.com/wmw-bra...0-r53-r52.html
Let us know if we can help you out
Old Mar 28, 2016 | 01:31 PM
Buggy's Avatar
Buggy
Thanks for all the great suggestions.
Being disabled and on SSD limited income, I'm leaning on these parts from Tire Rack because of the cost savings. In upstate New York here it's about $300.00 to $400.00 just to get them installed so I may purchase these items below. If anyone has bought and used these brake parts, I would love to hear your feedback.
Thanks again all for your assistance!!
Quote Details
Order Number: Q054434
Order Date: 03/21/2016
Shipping Method: UPS Ground
Items Shipping from: South Bend, IN
PRODUCTS QUOTED
Size & Description Qty Availability Price Each Item Total
AKEBONO EURO CERAMIC PADS
1 In Stock $70.00 $70.00
1 In Stock $65.00 $65.00
CENTRIC HIGH CARBON PLAIN 125 SERIES ROTOR
2 In Stock $33.00 $66.00
2 In Stock $41.00 $82.00
ATE TYPE 200 AMBER BRAKE FLUID
1 In Stock $21.50 $21.50
Old Mar 28, 2016 | 01:38 PM
PelicanParts.com
Vendor
Akebono is a good replacement pad. Good on low dust and noise. Those are pads that people commonly purchase on a lot of different brand vehicles. Not familiar with those rotors. Also, we have those pads and the fluid for less $$. Typically, $179 orders get free shipping or if the weight limit is over that, great discounted ground shipping. Just an option.
http://www.pelicanparts.com/catalog/..._pg1.htm#item3
Brembo rotors are less as well: http://www.pelicanparts.com/catalog/...pg3.htm#item13
Old Mar 28, 2016 | 02:14 PM
b6cool's Avatar
b6cool
akebono is good choice it is a well know name... i even had them on my audi.
centric rotors are good but make sure they have black coating on them for corrosion prevention. i have centric now on my mini but in slotted. and the price is still steep do more research and you will cut down another $40 on overall bill.
Old Mar 28, 2016 | 02:29 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I use Akebono and Centric a good combo. Should be under $300 for all four corners to install by an Indy shop. Pretty simple job.
Old Mar 28, 2016 | 02:57 PM
Capt_bj's Avatar
Capt_bj
you can get perfectly acceptable parts for your driving style at ANY major part store .... MINI parts were once hard to find ..... that was back 10 years ago .....
AutoZone and the similars ALL have the pads & rotors on the shelf {around me, anyway} . . . everyone here is recommending an 'upgrade' part which you DO NOT NEED. .....
Old Mar 28, 2016 | 03:47 PM
MINIKB's Avatar
MINIKB
I have Hawk pads and Stoptech slotted rotors on all 4 corners.
Very very low dust (if any) and very quiet.
Old Mar 30, 2016 | 07:38 AM
mustman's Avatar
mustman
just installed hawks on my r53. good pads but the cold bite leaves a bit to be desired. if you're only driving moderately, though, the low-dust factor is definitely a plus.
Old Jun 16, 2016 | 07:23 AM
Buggy's Avatar
Buggy
Want to belatedly thank everyone for the terrific insight and recommedations.
The final price include parts, installation and all taxes was $533.27.
I tried to place the order with Pelican, but I was on hold for 19 minutes trying to place an order. I thought what the service would be like if I had a service issue?
TireRack picked the phone on the second ring and the order shipped that afternoon and the process was flawless. Thinking if I had a service issue, I would feel confident utilizing TireRack by my treatment of placing the order.
Again, a Great Big thank you to all!
Superfun
May 22, 2016 09:31 PM
zkrpS
Feb 23, 2016 10:31 AM
Feb 22, 2016 02:54 PM
air1mtt
Feb 22, 2016 11:56 AM
d00lindalton
Feb 20, 2016 12:54 PM
