R60 225/55/17 on Countryman
Old Mar 15, 2016 | 04:11 PM
CountryS's Avatar
CountryS
Will be installing a new set of tires 225/55/17 on my Countryman tomorrow, has any other member installed this size on stock 17.
Old Mar 15, 2016 | 05:13 PM
devilmotorsports's Avatar
devilmotorsports
I found you this
Old Mar 15, 2016 | 05:30 PM
CountryS's Avatar
CountryS
thanks a million for the link, not much info on 225/55/17 but more on 225/50/17, I hope they will fit.
Old Mar 15, 2016 | 05:59 PM
devilmotorsports
I don't have them installed personally, but using some available online tools it looks like it should fit. Any time you change tire size its going to have an effect on your speedometer, between the 50 and 55 profile the the 50 has the least effect. Likely why there is so much more discussion on it.
205/55 vs 225/50:
Speedo error -3.05%
Reading at 30mph 29.09mph
Reading at 60mph 58.17mph
205/55 vs 225/55:
Speedo error -6.26%
Reading at 30mph 28.12mph
Reading at 60mph 56.25mph
Attached Thumbnails 225/55/17 on Countryman-50.gif   225/55/17 on Countryman-55.gif
Old Mar 16, 2016 | 02:19 AM
CountryS's Avatar
CountryS
Great info, thanks for taking the time to explain, I will give you an update tonight after a road test, the vehicle is stock in regards to the suspension and I don't carry heavy items.
Old Mar 16, 2016 | 05:10 AM
blacjakch's Avatar
blacjakch
I have the Continental Pro Contact DWS non runflats in that size and it was the best thing I ever did for a smoother ride. I used to have wicked tramlining but with these tires it all but went away.They do not rub or anything and an added benefit, they look beefier and will help the rims with any curb rash.They are very good tires in the rain and on dry ground. We didn't get much snow this year but the times she went out in the snow, she performed like a champ in the snow. I would definitely reccomend thes tires. Good luck!!
Old Mar 16, 2016 | 02:07 PM
CountryS's Avatar
CountryS
Well the tires are now installed and no rubbing, has great look and it seems like I'm ridding higher now... maybe my imagination.
Thanks for the info
Old Aug 26, 2018 | 03:49 PM
entropy1's Avatar
entropy1
205/55 vs 225/50:
Speedo error -3.05%
205/55 vs 225/55:
Speedo error -6.26%
I know this is an older thread, but for anyone that comes across this, just wanted to point out that the above information is wrong. Going from 205/55 to 225/55 yields a 3.35% increase in circumference (speedo error). Such an increase is considered mild and normal.
Will be running 225/55 on some 17x8 BMW wheels as a winter setup.
solomio
Oct 19, 2018 11:12 AM
quickcoop
Sep 21, 2018 03:40 PM
WildMini
Apr 8, 2016 07:23 AM
fishbulb
Mar 20, 2016 10:41 AM
Helix13mini
Mar 11, 2016 12:52 PM
