Wheel Lug Nuts Difficulties
Old Mar 12, 2016 | 06:49 PM
XsV's Avatar
XsV
So here's the backstory. I recently picked up some new wheels and sticky stuff for the track and made sure that I got ones that would fit standard OEM lug studs (12x1.5 right?). But upon further inspection of my current lugs, they look a little beat up.
So I wanted to buy some new ones to keep everything fresh but Tirerack wants to send me some acorns, local auto parts stores keep showing me acorns, and Mini wants WAY to much for them.
I have seen a few places like M7 and Way that offer conversion kits so that you can use acorn type nuts but how do these kits hold up under track conditions (high speed, cornering, heat, etc.)? Also, does anyone know of a company that offers lug studs in anything other than silver?
Old Mar 12, 2016 | 07:55 PM
isamin's Avatar
isamin
If you race the ride you'll need studs to pass tech. Shop around as all the vendors (check WAY=he's great) have them in one form or another. Satin black rattle can paint works wonders.
ISAMIN
Old Mar 12, 2016 | 08:01 PM
Gitmoe's Avatar
Gitmoe
Here.... http://www.sneed4speed.com/mini-coop...heel-stud-set/
Old Mar 13, 2016 | 06:11 AM
Wertles's Avatar
Wertles
I converted my BMW to studs since I swap tires often going to the track. Best decision I ever made. Most track cars I have seen have converted over. Just make sure to get some high quality studs and follow the installation instructions (usually red locktite and torque specifications).
Old Mar 13, 2016 | 11:48 AM
ZippyNH's Avatar
ZippyNH
Tuner lugs...very common...smaller top....or does the OEM fit those rims? My gut says test-fit them...
some like stud conversions...i did one...and undid it a year later...hated the look. Just bought a second set of correct sized "tuner" lugs....was about $50 from Gorilla.
Good lugs are not crazy $$, but they will cost ya $50 or more of you want fancy ones...
one tip..the ultra cheap "aluminium" acorn ones are junk...they are weak, and they will corrode in a few months...and require you cut them off, even if anodized.
Old Mar 14, 2016 | 07:58 AM
Just talked about hear with the studs , then you will need the correct lug nuts also for the type wheel. this is for R50 r52 r53 MINI up to 7/2006 12x1.5 size. In 7/2006+ they changed the size.
https://www.northamericanmotoring.co...on-on-hub.html
Old Mar 14, 2016 | 12:15 PM
XsV's Avatar
XsV
The wheels I bought fit OEM lugs. My question was more about whether or not to do the conversion or stick with OEM based on tracking the car occasionally.
zkrpS
Feb 23, 2016 10:31 AM
Feb 22, 2016 02:54 PM
d00lindalton
Feb 20, 2016 12:54 PM
jpinkerton
Feb 19, 2016 04:41 AM
Feb 16, 2016 11:07 AM
