Suspension Opinions on Lowering Options
Old Mar 9, 2016 | 06:34 PM
gtaccord's Avatar
gtaccord
Background
I finally convinced my wife to lower her Countryman S (non sport)
So I have done all the reading and research available on this site and others. Here are the options I am considering and pros cons.
Springs (HR or NM) plus Adj Rear LCA - $500
Cheapest option but I worry about the ride comfort and longevity of the stock non sport shocks
Springs plus Bilstein B4 or OEM Sport Struts/Shocks plus Adj Rear LCA - $700
Still concerned about the ride and longevity but it is a minor concern. This may be the best combination of price and performance.
Megan Coilovers plus Adj rear LCA - $1050
This is the most expensive option but from my understanding the best performing and best riding. I feel that these are overkill since I will likely only adjust these once. I would also prefer not to spend this much.
I just need some opinions. I have lowered a number of cars over the years and typically go with matched strut spring setups or coilovers so i am a little leery of the spring only options even with the upgraded "OEM" struts. If I do the mod and it rides crappy I will be in the doghouse.
Thanks for your help.
Old Mar 12, 2016 | 05:06 AM
12TrueBlue's Avatar
12TrueBlue
I just installed the Megan springs on my wife's "non-S" and I couldn't be any happier. I got them for $186 shipped and installed them myself. Pretty straight forward install. The change in handling in cornering is amazing as well. Just a thought if depending on how much $$$ you want to spend.
Old Mar 14, 2016 | 12:44 AM
eg3's Avatar
eg3
Here's my non-sport CM with H&R springs. 18x8 et40 wheels, 245/45 tires. It looks great and handles much better at nice roads. BUT if the roads where you live are crappy, I will suggest either going with Megans or getting Bilstein HD/sport package dampers with this setup. The non-sport dampers are too soft and the rear of the car becomes really jumpy. The front is ok but again the dampers are a little soft for proper shock absorbing with H&Rs.
All in all, from my previous feedback from R56 on Megans, I will suggest getting the coilovers. At worst, you can adjust it to the wife's liking.
I will also suggest NOT to go with a springs only option unless you have really really REALLY nice roads over there.
Old May 24, 2016 | 05:22 AM
64-bit's Avatar
64-bit
NM Springs are out everywhere, no one has in stock
I called their support and they said that all their springs gets manufactured in germany and they dont have an ETA when the new parts will arrive
ultrahuck
Mar 28, 2016 12:23 PM
1mini/m8
Mar 16, 2016 10:16 AM
zipitydooda
Feb 26, 2016 03:34 PM
BigBoost
Feb 24, 2016 06:06 PM
MothAudio
Suspension
Feb 24, 2016 01:43 PM
