Mini Cooper S Ecu Upgrade Gen3 F56 F55 F54 F57
Old Mar 9, 2016 | 12:43 PM
Mini Mania's Avatar
Part No: G3NME4310
Your Price $849.99
This is Special Order Only Item
JMTC Mini Cooper ECU upgrade for your 3rd generation F-Series Mini Cooper S. If you are looking for a safe ECU tune that makes the most power and torque possible - the JMTC ECU tune is THE solution.
Fits the following Mini Cooper S models:
2014+ F56 Mini Cooper S Hardtop
2015+ F55 Mini Cooper S Hardtop 4-Door
2016+ F54 Mini Cooper S Clubman
2016+ F57 Mini Cooper S Convertible
With over 20 years experience making power on many brands, JMTC now offers the ultimate solution for your MINI! The software upgrade maximizes performance by modifying boost pressures, air fuel ratios, ignition timing, throttle response and rev limiter just to name a few. We keep them in 'safe limits' for reliability while keeping your engine running strong. Whether you have a stock MINI or many modifications, JMTC ECU Upgrade can unleash the potential of your MINI.
FEATURES
  • Safe solution for Maximum Power Gains
  • Original ECU files are saved
  • Software Optimized to the mods on YOUR Mini
  • 20 Years experience with Chip Tuning
On a completely stock test vehicle (no modifications) with the JMTC ECU upgrade, horsepower went from 179.8 hp to 237.3 hp (+57.5 hp) and torque went from 215.5 lb-ft to 326.6 lb-ft (+111.1 lb-ft)!!! See the attached dyno sheet. (Dynapack Dyno) Your results may vary, but this was a very good indication of the potential for this upgrade!
IMPORTANT NOTES:
  • Intercooler upgrade is necessary for Stage 2 and above
  • Once ECU is removed from your Mini, DO NOT turn on ignition
  • Up to 20-25% power gains
  • Requires 91 Octane or higher fuel
  • ECU must be sent to AZ for the re-flash
  • Price includes 3-day return shipping. Expedited shipping available for additional fees
  • Details of your Mini necessary for proper tune
    • Year & Model of your Mini
    • List of ALL modifications
NOTE: Some states (like California) have ever tightening requirements for emissions testing and inspections. Always check your local regulations on compliance for street use.
Old Jan 12, 2020 | 10:54 PM
CarFreak427's Avatar
CarFreak427
Any chance these are still available?
Oct 12, 2015 02:43 PM
maxwin
Mar 6, 2011 10:55 AM
Kendel72
Mar 27, 2008 01:33 PM
steve11
Jul 21, 2007 02:20 AM
inmimini
Sep 7, 2005 08:31 AM
