JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Backup light on JCW rear bumper
Old Mar 1, 2016 | 09:39 PM
Kyu Tae Heo's Avatar
Kyu Tae Heo
I mounted JCW rear bumper with the lights, but the backup light connector pin is not match to my harness.
Anyone solve this problem??
Old Mar 2, 2016 | 03:14 AM
cerenkov's Avatar
cerenkov
I did. You will need the connector and leads from the dealer or someone like ECS Tuning. Then cut the wires, solder or crimp on the new leads, code out the bulb check error and you are good to go.
Blue wire is the reverse light.
Black w/ blue stripe is the fog light.
Brown is common.
The part numbers are:
The connector housing 61138373332 - you will need 2
https://www.ecstuning.com/Search/Sit...3332/ES165762/
The wire leads: 61130007256 - you will need 4
https://www.ecstuning.com/Search/Sit...256/ES2676207/
Since you no longer have a reverse light on one side you will get a bulb check error, so that can be coded out using NCS Expert. You will also need to code in the rear fog light and add the switch if you don't have rear fog option already.
Old Mar 2, 2016 | 06:01 AM
+1 Thanks cerenkov for the post, just saw this.
Old Dec 14, 2022 | 01:43 PM
CakeEater's Avatar
CakeEater
Can anyone confirm this will still work? Do the connector end of the leads go into the new socket housing? I am about to switch from stock LCI bumper to JCW bumper on my 2013 Cooper S. My car does not have the rear fog option so i just need the reverse lights. @ECSTuning
Old Dec 14, 2022 | 02:04 PM
Hello,
Just saw this was away from my desk helping some people out in our R&D.
yes you will switch the lights from this style and ends
to this
https://www.northamericanmotoring.com/forums/r56-hatch-talk-2007/295680-2013-jcw-back-up-light-question.html
https://www.northamericanmotoring.com/forums/electrical/246208-adding-a-second-back-up-light.html
Thats if you wanted to add the second but you can see how its set up. You will need that back up light for the JCW, fog light and the plugs/wires to tap in.
Old Dec 14, 2022 | 02:13 PM
CakeEater's Avatar
CakeEater
I currently have a reverse light on both sides like the below cooper. I would like to snip the 3 pole connector off of both sides and rewire both sides to a 2 pole connector that will connect right up to the reverse light on both sides. I would leave the rear fog light cable unused as i do not have a rear fog option on my car.
I have the following parts noted down as needed for the alteration:
2x 61138373332
4x 61130070582
Can you confirm that is correct?
Old Dec 14, 2022 | 02:20 PM
Yep if you just want that back up light.
A383Wing
Apr 30, 2019 02:05 PM
Velothree
Factory JCW Talk (2009+)
Dec 4, 2018 12:04 PM
Kevinp_27
Oct 30, 2018 05:43 AM
smarsha11
Electrical
Apr 6, 2016 03:26 AM
Trip024
Jan 15, 2007 08:13 PM
