R56 OPT7 LED base model headlight bulb replace
Hi,
I have OPT7 CREE 80w H4 9003 LED 6000k replacement headlight bulbs I installed and they work great except there is a gap in the light pattern. Right side is perfect. Light just in front of the car, along the far right side, and down the road quite a ways. Left is fine except a considerable black rectangle on the left mid way out, and far out slightly into the center. If starts probably 30 feet forward, then is crisply cut off. I don't think I can adjust the left light to the left much or the far center part will blind oncoming drivers.
Anyone encounter this? What did you do to resolve t?
I had to return these. Too much glare for on coming traffic if you don't have a projector lense and I couldn't get the beam pattern right either. They flickered for a few seconds on start up and are not DOT legal. I liked the color a lot but just didn't work out. Went with PIAA's xtreme white. Better than stock and are DOT legal.
PelicanParts.com
Feb 10, 2016 10:52 AM
banyan
Jan 31, 2016 06:01 PM
PelicanParts.com
Jan 25, 2016 03:19 PM
