R50/53 Rear brake rotor supplements?
Old Feb 15, 2016 | 10:08 AM
sevin's Avatar
sevin
ECS is currently having a sale and their Geomet slotted rear brake rotors are 50% off. I machined my front rotors last week and measured the rears and they were about .015" under spec, so this is a perfectly timed sale! I'm just wondering if it's necessary to replace anything else while I'm there. Should pads be replaced? Should front rotors be done too?
Old Feb 15, 2016 | 10:59 AM
joshua stowe's Avatar
joshua stowe
Pads should always be replaced when rotors are. Also it's a good time to do some maintenance of the calipers and suspension parts
Old Feb 15, 2016 | 11:00 AM
joshua stowe
Also rears are only around 20% of your stopping power. I'd upgrade the front first
Old Feb 15, 2016 | 11:02 AM
sevin's Avatar
sevin
I know they only do 20-40% of the braking, but they're on sale so why not. If I had the money I'd do the front too, but I don't and they are not the ones under spec. I'll see about doing my pads. Thanks!
Old Feb 15, 2016 | 11:04 AM
joshua stowe
If it's deal go ahead. Old pads will destroy rotors pretty fast so make sure the pads are new or smooth
I've got a wilwood big brake kit on my fronts and stock rears
Old Feb 15, 2016 | 11:07 AM
sevin's Avatar
sevin
I'm planning on getting the same rotors for the front and EBC Redstuff pads. I guess I'll just get OEM pads for the rears? I was going to get the EBC rears, but I guess it's not necessary. I'd like to keep the dust down though since I've got those white R85's.
Old Feb 15, 2016 | 03:47 PM
sevin's Avatar
sevin
Ok, so getting the EBC pads and ECS rotors would be about $170. I don't really want to spend that right now so I'm wondering if it is actually necessary to replace my rotors at all. They are .015" under spec. Will continuing to run them present a big safety concern, or can I get away with it for now? I don't really want to miss out on the sale either though...
Old Feb 15, 2016 | 04:02 PM
joshua stowe
It just mean their work down and will hear up and possibly crack. I'd change them soon.
I kinda wonder how different mini rotors are from Honda cubic rotors
Old Feb 15, 2016 | 04:05 PM
joshua stowe
God auto correct. Worn down and heat up
Old Feb 16, 2016 | 08:53 AM
Saltysalt's Avatar
Saltysalt
.015 is a very small distance, its about 2 sheets of paper. while you should keep this in your mind and replace them soon you can still use them for a little while
Old Feb 16, 2016 | 10:05 AM
sevin's Avatar
sevin
I just want to take advantage of the sale. Will running new rotors on pads that have ~80% life left damage the rotors quickly? If it's necessary to replace pads even when the pads I have are fairly new, then I'll just hold off.
Old Feb 16, 2016 | 12:36 PM
Saltysalt's Avatar
Saltysalt
if the rotors you currently have, have any witness lines or grooving, the new rotors will gain that very quickly, if they are nice and smooth, the new rotors will be nice and smooth. but it all depends on what is harder. the harder item will wear the softer item
Old Feb 16, 2016 | 12:50 PM
sevin's Avatar
sevin
I went ahead and ordered the rotors. Figured I was being kind of stupid; there's no need to put them on immediately so why not grab them while they're cheap(er). I'm just going to hold off on installing them until the pads need replacing since my old rotors are not totally smooth.
kxmini
Feb 4, 2016 10:24 AM
RB-MINI
Suspension
Jan 24, 2016 07:44 PM
sir5150
Jan 23, 2016 10:45 AM
Smitha6
Jan 19, 2016 11:01 PM
vulkandino
Jan 16, 2016 10:59 PM
