Drivetrain N14 JCW Turbo to N18 S Engine.
Old Feb 12, 2016 | 04:19 PM
Drexial's Avatar
Drexial
OK, I hate to do a post for something that I know is posted somewhere already. But I can seem to find this specific information.
Anyway, my turbo doesn't sound too happy. I want to get it swapped out and want to know all my options. I have already looked at a lot of aftermarket upgrades and hybrid turbo options. But I think I am going to go for a more cost effective option now, buy the supporting mods first, then introduce a better turbo into the mix.
I am eyeing up a turbo and from what I have seen the Turbo's sold for JCW and S's list all model years from 07-13 (or 15-16 depending on application)
But I was wondering if there would be any concerns going with an N14 Turbo on an N18 engine. Are there any reasons I shouldn't get the turbo from the N14s?
As far as I have read otherwise, I am good to go with without issue on swapping in a JCW turbo, and even recommended if I need to replace it anyway.
I am also wondering in the case of that swap, would there be anything different in the parts I order, such as oil feed lines and gasket kits?
And why not for good measure ask another question, more of a point of recommendation, I figured if I was getting a used one, I should do a rebuild kit on it. Anyone do their own rebuild? I have watched a few videos on rebuilds and they don't seem to complicated. I do consider myself competent when it comes to mechanical work, Turbo's are just something I haven't handled myself before and there is that slight fear of the unknown. Something spooling at 20k+ just seems like something small could make it go horribly wrong. Is there a recommended interval that a rebuild kit should be installed?
OK I think that's enough for now. Thanks for any info.
Old Feb 17, 2016 | 01:21 AM
johntotah94's Avatar
johntotah94
As far as I know all the turbos are the same. When you purchase turbos like my E45R, they say for 2007 and up models.
Old Feb 17, 2016 | 02:35 AM
cerenkov's Avatar
cerenkov
Too bad... I just sold my low mileage turbo from my 2013 N18 S for $400 after swapping to the N18 JCW version.
Try and find a low mileage turbo and you should not have worry about a rebuild. I would leave rebuilds to the experienced specialist anyway.
All the turbos should just bolt on. There may be minor updated internal differences but you should not be able to tell.
As far as consumables. Those too should be the same, I ordered all my from ECS Tuning after getting part numbers from www.realoem.com. Don't forget the copper crush gaskets for the turbo coolant line banjo bolts, you need 4. Get the upgraded oil feed line from Detroit Tuned.
If you do go with the JCW version you may need to get the larger diameter JCW air inlet. Some people have modified their original inlet pipe with some luck.
Old May 27, 2019 | 06:11 AM
Morci's Avatar
Morci
Hello! Do you think can i do the same on my Cooper S N18, upgrading with JCW n14 turbo?
Thanks in advance!
Old May 27, 2019 | 07:57 AM
MarioKart's Avatar
MarioKart
Vendor
Thanks in advance!
The turbos can be swapped around with out issues. Please make sure to use new gaskets and a new oil feed line (they only liked to be used once)
Mario
mQubed Motorsport Manic & RPM Power Tuning
Old May 28, 2019 | 12:26 AM
Morci's Avatar
Morci
Mario
Thank you so much for your reply!
Old Jun 3, 2019 | 09:57 AM
Drexial's Avatar
Drexial
I think I saw this a couple days ago and didn't realize it was my own post from 3 years ago.
For a definitive answer, yes I did exactly as the title states. The only differences are the turbo intake opening is slightly larger, but a tiny bit of lube will allow the intake tube to easily slide right on and there is one mounting screw that isn't used for the top coolant line, there is a blank space where it would go, but no hole, it's not entirely needed as it is a ridged line. EDIT(I might be wrong about this part, there may be a difference between the S and JCW parts for the N14 turbos. For some reason I recall not seeing it, but as I look there is clearly a threaded hole there on the N14 JCW turbo)
There are gasket kits out there and some upgrades for the oil intake line for the turbo, If you have any questions about the work, let me know, as I have just done this a second time and there are some lessons I had to learn twice.
Old Jun 3, 2019 | 10:26 AM
Morci's Avatar
Morci
Thank you so much for your answer, really.
Past week i have made turbo swap on a MINI workshop specialist and he has made the work flawlessy!
I have changee the oil feed, and some other minor things.. and the day after that, i have done an Stage 2 getting near to 260cv and 380nm of torque.
Now i can hear the new turbo breathing! Really loving it!
Thanks again for your answer, and your help intention. Really appreciate it.
All the best
Old Apr 7, 2025 | 12:34 PM
pkgmSu2000's Avatar
pkgmSu2000
Same JCW turbo both N14 and N18??
Old Apr 7, 2025 | 01:03 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
There are technically a few different part numbers, but they are all physically interchangeable.
Old Apr 7, 2025 | 01:04 PM
pkgmSu2000's Avatar
pkgmSu2000
great so it bolts right up eh? Always appreciate your help
Tweedbean
Sep 20, 2018 06:41 AM
WayMotorWorks
Jan 28, 2016 09:24 PM
03cooperr53
Jan 21, 2016 02:09 PM
skucera
Jan 20, 2016 05:19 AM
EnzoF61
Jan 15, 2016 07:32 PM
