R60 Something you discovered AFTER you bought the Countryman
Old Feb 1, 2016 | 08:30 PM
offapex's Avatar
offapex
Maybe a fun little thread...what's something you discovered after you got the car? I've had mine for about 2 days now and discovered (via a YouTube video) that you can move the back seats back/forth for addition trunk space. Sure enough you can! This will come in handy for sure.
Old Feb 2, 2016 | 05:27 AM
rkj__'s Avatar
rkj__
I've only had run of the mill domestic vehicles before, so there were a number of things that were new to me on the Mini.
The wheel studs come off, not just nuts. I've never had that before. Discovered that when I put winter tires on.
Rain sensing wipers. Did not know the car had those until I read the manual.
The car has super bright xenon headlights, and the rear view mirror is auto dimming. I only test drove in the daylight.
Old Feb 2, 2016 | 07:43 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I found out that the highway noise on an hour plus drive would drive me insane if I did it daily. Thankfully it's only a few times a month.
Old Feb 2, 2016 | 08:05 AM
The X Men's Avatar
The X Men
I found out the rear headrest goes all the way to give me a better view of the rear.
Old Feb 2, 2016 | 08:21 AM
offapex's Avatar
offapex
It took me a little googling to find out how to do this with the 2 buttons needed. I would have been really annoyed if it could not go all the way down.
Old Feb 2, 2016 | 11:18 AM
osinkboy's Avatar
osinkboy
two words: disco mode
Old Feb 2, 2016 | 11:40 AM
Burgh Bhoy '67's Avatar
Burgh Bhoy '67
Opening all four windows and the sunroof with remote
Old Feb 2, 2016 | 11:45 AM
osinkboy's Avatar
osinkboy
do you know if you can close the windows with the remote somehow?
Old Feb 2, 2016 | 03:26 PM
JuanTheHuman's Avatar
JuanTheHuman
Hey! Dude, help me out! How did you solve this? Thanks!
Old Feb 2, 2016 | 03:39 PM
offapex's Avatar
offapex
The main button allows you to move the headrest up/down. Opposite side there is a smaller, barely visible button. You have to use a key or screwdriver tip to press it in. If you press both buttons in at the same time then you can fully push the headrest down!!!! I would have been really annoyed if this was not possible.
Old Feb 2, 2016 | 03:52 PM
Kimsc321's Avatar
Kimsc321
not only the windows but, sunroof as well - open AND close. you need to reprogram the code via NCSExpert program. See if anyone in this forum who lives around your neighborhood would do it for you.
steven
Old Feb 2, 2016 | 10:39 PM
BrandonM3's Avatar
BrandonM3
Nope, just open. In stock form at least.
Old Feb 3, 2016 | 03:21 AM
bmwr606's Avatar
bmwr606
check out the carly app for iphone and android ... does the same coding as ncsexpert but all you do is select check-boxes of the setting you want to change
is is not free
it does much more than coding such as real-time monitoring, read and clear CELs and program new battery to car
Old Feb 6, 2016 | 07:09 AM
MG2782's Avatar
MG2782
I found out my armrest had storage in it 2 days after I bought my 2016, lol. Thought I felt a button when I test drove it, but it didn't seem to do anything, then 2 days later I was fiddling and it opened, lol.
I learned that the clipboard I use for work insists on being buckled in, per the passenger safety belt warning I get when it's on my passenger seat, lol.
I'm on day 3, I'm sure I'll be adding to this list
Old Feb 7, 2016 | 06:56 AM
imanexcellentdriver's Avatar
imanexcellentdriver
On the good side:
Gearing on the 6-speed is good...just got a reg Cooper as a loaner and 1-2-3 is WAY too tall...made me appreciate my gearbox so much more.
If you push and hold the "lock" button on the door handle after you get out, all the windows will close.
While not totally intuitive, the bluetooth connection to my iPhone/iTunes is pretty seamless.
"Sport" mode makes that beautiful lift throttle burble :>
On the not good side:
Brought my stock CM-S All4 out to Streets of Willow for a track day and it seems they made everything bigger on that car except the clutch and the brakes...15 minutes into a 20 minute session the brakes started to fade...and the clutch gets smelly if you try to do a high RPM launch...(of course there are mods, but I'm on a lease...maybe JCW would've helped?)
Old Feb 7, 2016 | 07:18 AM
Luman Ator's Avatar
Luman Ator
Vibration
My girlfriend just bought a 2011 Cooper S ALl4 4 door from the dealer while driving it home she notice that it has little vibration or something Thursday night I take it for ride first time and noticed a little vibration feels like a hop cv joint front axle maybe bad bearing or Tire , I haven't really went looked at it yet it it has 52000 miles any ideas or experiences of the time like this thank you
Old Feb 7, 2016 | 07:27 AM
imanexcellentdriver
LumanAtor,
Do you notice the vibration at specific speeds? Probably wheel balance or worn/cupped tires. If it's pretty constant or random, I'd look at CV joints or suspension bushings.
Old Feb 8, 2016 | 08:54 AM
HJCPmeek's Avatar
HJCPmeek
My vib that I had ended up being rear differential issues... found it on an oil change, luckily I had an extended warranty.
Old Feb 11, 2016 | 12:15 PM
MLH44's Avatar
MLH44
Luv Disco Mode. Now, if only I could find a MINI crystal ball for under the mirror. There's has to be one out there somewhere.
Old Feb 11, 2016 | 12:39 PM
Burgh Bhoy '67
I just discovered the hatch unlock button in the driver's foot well near the hood(bonnet) release.....I am pretty sure that was not on my 2012 All4
Old Feb 11, 2016 | 05:23 PM
Deuce_Coop's Avatar
Deuce_Coop
Do tell! How do you get into Disco Mode?
Old Feb 11, 2016 | 06:22 PM
osinkboy's Avatar
osinkboy
here you go
Old Feb 12, 2016 | 04:03 AM
Deuce_Coop's Avatar
Deuce_Coop
The car seat occupants in the back seat are going to love it!!
Old Feb 14, 2016 | 05:45 PM
bmwr606's Avatar
bmwr606
i was browsing on aliexpress today and found a mini disco ball!
Attached Thumbnails Something you discovered AFTER you bought the Countryman-screenshot_2016-02-14-02-54-09.png
Old Feb 15, 2016 | 09:36 AM
Mistiplix's Avatar
Mistiplix
Devil in the details...
So my first day solo and without a giant purse, the passenger airbag light on the dome console would not stay off. Creeped me out. The warning that I will not be protected if I am somehow wrenched sideways during impact is not a comfort. Depending on where I put my bag or backpack, the light goes off.
I really wish the nighttime instrument display panel would disco/rotate as well. Save me from all the orange.
I love the tiny gas tank. Is that weird? It just fills up in no time. No more dancing around in the cold waiting to fill up!
The driver side sun visor is installed crooked. You can't tell until you unfold it and get a wonky view of a sun-splashed road ahead. I'm now thinking about where to put a sunglasses holder.
