R60 Cooling system replacement intervals
Old Jan 16, 2016 | 07:45 AM
BrandonM3's Avatar
BrandonM3
Hi all!
I'm about a year into my transition from BMWs to MINIs and couldn't be more validated in my decision. Quick question about the cooling systems in these cars. In BMWs, it's a pretty standard practice to replace the main cooling system components (radiator, main hoses, water pump, and thermostat) every 75,000 miles or thereabouts. Is this a thing for MINI's too?
Cheers!
B
Old Jan 16, 2016 | 08:22 AM
elvis cole's Avatar
elvis cole
Replace the cooling components every 75K??? Really???
Old Jan 16, 2016 | 12:12 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
The plastic bits can be problematic and being proactive isn't a bad idea because they will fail eventually. Don't know if your timetable is on target. My last BMW had 110,000 on it with original components.
Old Jan 18, 2016 | 11:32 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Most replace when they leak or you can do preventative and replace before they leak. One often neglected task on many cars is the maintenance of the cooling system. Be sure to change/flush your coolant and to not neglect this task.
888.280.7799 | 6am - 5pm PST
Old Jan 18, 2016 | 01:14 PM
Originally Posted by BrandonM3
Hi all!
Cheers!
B
Onwed many BMW and MINIs. The MINI don't have the cooling hose issue, ( other then the Gen 2 cooling pipe ) but the coolant will need flushed every so offten years and the water pumps, thermostats, expansion tank. and housing can be an issue. Most people do it all at once.
Radiators are not an issue unless very high mileage. But the heater cores can be an issue.
Let me know if you need anything. I owned many of both. How many miles do you have ?
Old Jan 21, 2016 | 02:59 PM
BrandonM3's Avatar
BrandonM3
Gotcha. OK good to know. My CM has 14,000 miles, so no need anytime soon. BUT, my wife's 2010 R56 Justa has about 120,000 miles. So that's the real reason I'm asking. Thoughts?
Old Jan 21, 2016 | 03:07 PM
PelicanParts.com
Vendor
If it's not leaking, then you should be fine, but if you feel up to it you can inspect them and replace the components at a preventative measure. Have you done a flush yet in the R56? In general, it's recommended that you flush and clean out your cooling system once every 36 months, or approximately every three years. Sometimes I do it every 1 or 2 years. The reason for this is that old, exhausted coolant can actually cause irreversible damage to your engine components: We here at Pelican found this out firsthand when the head gasket on our '93 BMW 325is was replaced. The previous owner didn't look like he had changed the fluid once in the past ten years. As a result, there were many parts of the engine that were corroded and showing severe signs of wear.
Old Jan 22, 2016 | 07:13 AM
Welcome, the hoses should be fine, but I would thermostat housing, water pump, water pipe, and expansion tank , if it has not all been done. That covers all the prone fail parts.
Water pump DIY here : https://www.northamericanmotoring.co...acement-3.html
Post #62
Thermostat housing here : https://www.northamericanmotoring.co...hermostat.html
Parts : , in R56 2010 MINI Cooper ( NON S ) from 6/2010 will need the adapter lead also.
https://www.ecstuning.com/Mini-2010-...ngine/Cooling/
12517646145
jeph swift
Nov 20, 2023 10:00 AM
scottbushey
Feb 7, 2017 09:55 PM
Dec 3, 2015 11:18 AM
Colt45Magnus
Dec 3, 2015 08:53 AM
genik
Nov 29, 2015 12:04 AM
