R50/53 Installing coilovers questions
Old Jan 14, 2016 | 11:23 PM
mini_mike237's Avatar
mini_mike237
This is probably a dumb question but I'm about to order ksport coilovers for my 2005 base Mini Cooper and when I select it for my car it says they will not fit my car, but how ever when I select it for Cooper S they say it will fit . So the question is does it really matter if it's for the S or not ? (Just want to make sure before I waste time/money) thanks in advance
Old Jan 15, 2016 | 07:09 AM
Saltysalt's Avatar
Saltysalt
it should not make a difference
Old Jan 15, 2016 | 09:55 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You should be fine. As you can see the coil overs from ST below for the '05 base and S are the same part number. You can also always go to the manufactures website as they should have an application guide for their product.
Base - http://www.pelicanparts.com/catalog/...pg3.htm#item19
S - http://www.pelicanparts.com/catalog/...pg3.htm#item19
888.280.7799 | 6am - 5pm PST
Old Jan 15, 2016 | 12:16 PM
I show and so does Ksport website https://www.ecstuning.com/Search/SiteSearch/CBM070-KP/ is for the Cooper R50 2002-2006 CBM070-KP/
https://www.ecstuning.com/Search/SiteSearch/CBM072-KP/
is for the Cooper S R53 2002-2006 CBM072-KP
Show the same spring rates , but sometimes they change the valving or something else based off the weights or the cars, the S has more front weight.
got_mini?
Mar 12, 2016 01:00 PM
Chris62401
R55 :: Clubman Talk (2008+)
Dec 7, 2015 10:56 AM
mikehks
Dec 6, 2015 06:56 AM
Suspension Products
Dec 4, 2015 04:51 PM
Dec 3, 2015 11:18 AM
