R56 Mini broke
Old Jan 13, 2016 | 09:24 AM
BadgeFTW's Avatar
BadgeFTW
From: Greenville, SC in the United States of Awsome
Mini broke
My 2008 R56 103,000 miles will not start, the ignition goes but engine wont start.
Old Jan 13, 2016 | 09:57 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did you check over the basics, i.e. check for spark and fuel? Any codes present in the system?
888.280.7799 | 6am - 5pm PST
Old Jan 13, 2016 | 10:10 AM
BadgeFTW's Avatar
BadgeFTW
there is gas and i can hear ignition, what do you mean codes? Im not much of a mechanic.
Old Jan 13, 2016 | 10:21 AM
PelicanParts.com
Vendor
Although you are getting it to crank, still check the battery so that you can rule it out of the equation. I have seen instances where a bad battery was in the mix of things even if the vehicle cranked. Be sure to check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Do you have a scan tool that you can plug into your OBDII port to see if any faults are present in the system?
https://www.northamericanmotoring.co...n-t-start.html
http://www.mini2.com/forum/second-ge...-starting.html
Old Jan 13, 2016 | 10:40 AM
BadgeFTW's Avatar
BadgeFTW
No scan tool, thanks for the help
Old Jan 13, 2016 | 11:51 AM
We have one here for MINI specifically.
We just landed this Schwaben by Foxwell tool and it reads allot of things, I used it for ABS testing and it pulls and tells which side is bad. Also found allot of old stored codes for a dead battery in my R58 which is like a history lesson of the car, showed the faults in the climate control for the low battery. Unlike my Actron unit , which took a couple time, this read codes right of the bat. Pretty cool device and read much more. What it all preforms is listed in the Product Details on the item.
Once you have a check engine light or sometimes it will find codes that dont have a Check engine light, you can find that P code PXXXX and then google search it or copy and paste into the MINI forums search box and presto , you have some answers.
Professional BMW/MINI Scan Tool
https://www.ecstuning.com/Search/SiteSearch/ES2975699/
Old Jan 13, 2016 | 11:56 AM
PelicanParts.com
Vendor
You could swing by your local Autozone and see if they can pull a code for you if you do not wish to buy a scan tool, but obviously would need a running car. Maybe you can borrow one from a friend? Once you do some digging let me know what you find out.
Old Jan 13, 2016 | 01:28 PM
BadgeFTW's Avatar
BadgeFTW
i have a freind coming over to help me figure out the problom, ill let you guys know.
Old Jan 13, 2016 | 01:31 PM
Thanks for the update, try to scan it with an actron unit ?
Old Feb 4, 2016 | 02:30 PM
BadgeFTW's Avatar
BadgeFTW
Sorry to revive this tread, but my timing chain/belt died, whats the damage? Mechanic says its totalled.
Old Feb 4, 2016 | 02:33 PM
PelicanParts.com
Vendor
You going to buy a new motor or depending on the extent of the damage do a rebuild?
Old Feb 4, 2016 | 02:34 PM
Oh no. ;( If the heads make contact with the valves, then the pistons and valve train , plus rebuild the head and timing. If more broke or bent in the engine then the cost of a remain would be cheaper or a salvage one.
Factory Remain went up in price since last year :
https://www.ecstuning.com/Search/SiteSearch/11002158705KT/
Old Feb 4, 2016 | 07:07 PM
JimmyChooToo's Avatar
JimmyChooToo
$3,500 on EBay for a turbo engine without the turbo.
Old Feb 5, 2016 | 08:13 AM
BadgeFTW's Avatar
BadgeFTW
I am going to head to the mini dealer becuase i belive there was a recall for it. I may have to buy a new mini
Old Feb 5, 2016 | 08:19 AM
PelicanParts.com
Vendor
Sorry to hear. Let us know what happens.
Old Feb 5, 2016 | 08:26 AM
I am going to head to the mini dealer becuase i belive there was a recall for it. I may have to buy a new mini 😢
There was a TSB were one of the cars with the updated tensioner bulletin. if yours was not done. I had mine done. You can call the dealer and they can run your vin. It was 2007-~2009 MCS that had the older tensioner style and if your chain was stretched they replaced it also. If you have the old tensioner or the the TSB had not been done, they might work with you.
https://www.northamericanmotoring.co...00-mini-s.html
Old Feb 5, 2016 | 09:52 AM
BadgeFTW's Avatar
BadgeFTW
Dealer said they will fix it becuase my mini was under the November recall. Hopes up
Old Feb 5, 2016 | 09:54 AM
PelicanParts.com
Vendor
whooo-hooo!! Happy to hear this.
Old Feb 5, 2016 | 09:55 AM
BadgeFTW's Avatar
BadgeFTW
R.I.P n14 2008-2016 :'(, at least im getting a replacement.
Old Feb 5, 2016 | 10:04 AM
That's great news, glad they came through. If you need anything else I am always here to help.
Old Feb 5, 2016 | 10:10 AM
BadgeFTW's Avatar
BadgeFTW
thanks
Old Feb 5, 2016 | 10:14 AM
Welcome. I am here for my fellow N14 owners.
Old Feb 5, 2016 | 12:31 PM
Systemlord's Avatar
Systemlord
The November recall? Why would Mini replace the entire engine?
Old Feb 7, 2016 | 07:26 AM
BadgeFTW's Avatar
BadgeFTW
becuase the car is now dead becuase it was never replaced.
Old Feb 7, 2016 | 08:47 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Then, there is this: http://topclassactions.com/lawsuit-s...on-settlement/
