F55/F56 New mini, need wheel spacers
Old Jan 11, 2016 | 12:44 PM
giancarlo90's Avatar
giancarlo90
Hi Everyone, first time posting here.
Just bought a 2016 Mini Cooper with 17 inch wheels and wanted to know which wheel spacer size fits the best so the wheels look flush with the flares.
And what brand is the best?
This is the Cooper
Thank you
Old Jan 11, 2016 | 01:33 PM
ECS Spacers : Comes with the correct length bolts in black.
F56
https://www.ecstuning.com/Mini-2014-...heels/Spacers/
~ 8mm front / 15mm rear most people with 17" factory wheels.
https://www.northamericanmotoring.co...us-kw-bmc.html
On the F55
https://www.northamericanmotoring.co...el-spacer.html
Old Jan 11, 2016 | 06:38 PM
MiniLynsk's Avatar
MiniLynsk
ECS , what size would sit flush for 16" wheels?
Old Jan 11, 2016 | 08:48 PM
pppdxx's Avatar
pppdxx
Can I use spacers on my 15" snow tires?
Old Jan 11, 2016 | 09:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've had many use our WMW 5mm spacers in the front
http://www.waymotorworks.com/5mm-whe...-f56-mini.html
and our 15mm spacers in the rear
http://www.waymotorworks.com/15mm-wh...-f56-mini.html
this made the car we had look pretty flush and didn't rub.
Old Jan 11, 2016 | 10:51 PM
mattcarberry's Avatar
mattcarberry
F56
On the F55
What do you suggest for an f56 with 18's and nm springs?
Old Jan 12, 2016 | 05:07 AM
See Below.
Yes.
See below.
I just have examples of a few with the F56 17" as posted above, as the wheels spacers are new to the F56 game.
Every car set up dependent on wheels and lowering will set different. The Best way to find out is to do the wheel measure with your set up now before spacers. You just need some common household tools and go out to your car on a level surface.
Here is a great video to show you how to measure for spacers to get that flush look.
Then the spacers are linked above, all sizes.
Old Sep 10, 2016 | 04:05 PM
mcoopers81's Avatar
mcoopers81
F56
On the F55
What if I'm running the 18" stock wheels? Would those dimensions work too?
Old Sep 12, 2016 | 12:23 PM
Yes, the wheel is bigger so if really lowered you might be closer to the wheel well. Stock height you are fine. But the ET 54 is the same offset for the 17" and 18" stock wheels .
Old Sep 12, 2016 | 02:13 PM
mcoopers81's Avatar
mcoopers81
Awesome! So even when taking tight corners I should be fine at stock height? On my R56 I kept everything stock. But now I'm exploring a little further with my F56 so forgive me if I sound like a noob.
Old Sep 12, 2016 | 02:15 PM
Yes,
Old Sep 12, 2016 | 02:34 PM
mcoopers81's Avatar
mcoopers81
Yes,
:thumbs: Thank you!
Old Sep 12, 2016 | 07:53 PM
DustinFennell's Avatar
DustinFennell
I have ECS spacers on my Audi SQ5. Never had an issue with them. They are of great quality.
By they way, great choice on color!
Old Sep 13, 2016 | 06:34 AM
Originally Posted by mcoopers81
:thumbs: Thank you!
Welcome.
Old Sep 13, 2016 | 06:36 AM
Thanks , I appreciate it.
Old Sep 13, 2016 | 08:59 AM
isamin's Avatar
isamin
Before I modified my JCW's stance I went to Harbor Freight (you know,cuz all us been dare) and bought some real cheapo plastic measuring devices that were reasonably accurate and figured with a 12.5 spacer up front ,none in back, I could use a 7.5 wheel with abackspacing of ET45 on which I could safely mount 235/40/17 rubber. WOW-they fit with NO RUBBING. Plus the car looks real BADASS.
ISAMIN
Old Sep 13, 2016 | 09:17 AM
sootyvrs's Avatar
sootyvrs
ISAMIN
Any pics? Are you talking about the F56 as that width offset doesn't seem possible?
Old Sep 13, 2016 | 01:25 PM
atlantaorange's Avatar
atlantaorange
i just lowered mine with NM springs
I have the 17X8 stock wheels with 215 series pilot super sports
I am running 15mm all around. I dont have any rubbing, however, i think the fronts are just a tad wide
(ignore the leaf in the background, that is a friends)
Old Sep 15, 2016 | 04:54 PM
stephenthorn82's Avatar
stephenthorn82
I have kw coilovers with 10mm front 15 mm rear. I think in general the fronts will always poke 5mm more than the rear depending on camber.
Old Sep 28, 2016 | 09:12 PM
Joespeed's Avatar
Joespeed
I have 20mm spacers in the rears.. no rubbing that I'm aware of
18" factory wheels
Old Sep 29, 2016 | 11:29 AM
^^ Looks very close to flush. Well done. Are you poking on the rear with the 18".
Old Sep 29, 2016 | 06:05 PM
Joespeed's Avatar
Joespeed
not sure what you mean by "poking"
Old Sep 30, 2016 | 06:44 AM
Does the wheel / tire stick out past the rear fender?
Old Sep 30, 2016 | 10:08 AM
Joespeed's Avatar
Joespeed
well I mean, the rear bumper curves in after the reflector.. so yea it sticks out.. but its a natural curve I suppose..
Old Sep 30, 2016 | 10:17 AM
At the top the wheel arch. Which it looks like you are flush. Well done.
