R60 Water Pump Failure ?
Old Jan 10, 2016 | 10:08 AM
pbkirby's Avatar
pbkirby
I've been seeing what looks to be a coolant leak (dark greenish fluid) and from other posts sounds like a failing water pump. Do I change the thermostat and coolant temp sensor all at once ? CMS has 64K on it.
Old Jan 10, 2016 | 03:21 PM
minicountry's Avatar
minicountry
Yes both pump and thermostat, had mine replaced under warranty
Old Jan 10, 2016 | 10:00 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You only need to change the thermostat and temp sensor if they are actually failed as they are on the other side of the engine so the labor doesn't overlap.
We keep the new all aluminum pumps in stock
http://www.waymotorworks.com/water-p...8-r59-r60.html
Old Jan 17, 2016 | 11:39 AM
pbkirby's Avatar
pbkirby
Coolant leak
Leaking about 2 quarters (size) every few days. Nothing to worry about or should I get the pump changed soon.
Old Jan 17, 2016 | 04:55 PM
dpike's Avatar
dpike
i've had mine done twice. from what i understand the housing for the pump is made of plastic and cracks with rapid heating and cooling. if the dealer replaces yours they will probably do so with the plastic one again.
Old Jan 17, 2016 | 05:22 PM
pbkirby's Avatar
pbkirby
I'm out of warranty (65K miles) so I guess its on me
Old Jan 17, 2016 | 05:44 PM
WayMotorWorks
Vendor
I would do it sooner than later since you don't have a temp gauge you won't know until its too late if it looses too much.
Old Jan 17, 2016 | 06:42 PM
pbkirby's Avatar
pbkirby
I check the overflow tank every few days
Had to put some in last week, about 30 oz, nothing in the past few days
Old Jan 17, 2016 | 07:12 PM
mikey_t's Avatar
mikey_t
Everyone is telling you to get it changed. Heed their advice...
Old Jan 18, 2016 | 11:25 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Replace the water pump if it's leaking. We have them here. Genuine or OEM supplier is recommended. Be sure to use MINI coolant HERE 50/50 mixed with distilled water.
888.280.7799 | 6am - 5pm PST
Old Jan 18, 2016 | 01:20 PM
What year do you have ? Yes I would do the Waterpump and the thermo at the same time.
Old Jan 31, 2016 | 01:45 PM
pbkirby's Avatar
pbkirby
Fixed
Water pump, large coolant hose and thermostat replaced for $1100 all in with Mini Club discount. Ouch ! She's good for another 65K or so I guess
Old Jan 31, 2016 | 02:19 PM
minicountry
Did they put a metal one or just plastic?
Old Feb 1, 2016 | 11:08 AM
All the Genuine MINI ones Water pumps are all metal on the outside as well as the aftermarket ones we carry the Febi one has a metal impeller also. 11517648827
https://www.northamericanmotoring.co...8-no-heat.html
daonlyillwiz
R60/R61 Stock Problems/Issues
44
Jul 18, 2023 06:06 AM
[My_Mini]
Jan 11, 2016 12:31 PM
michelenye
Jan 6, 2016 04:13 PM
Robert Pritchard
R55 :: Clubman Talk (2008+)
Jan 6, 2016 08:20 AM
jennster
Jan 5, 2016 06:14 PM
